Tom's Hardware > Forum > CPU & Components > CPUs > Help - my old P4 took a nose diveelp
Forum CPU & Components : CPUs - Help - my old P4 took a nose diveelp
So I bought a new computer (q6600, P5Q pro, 8800gt) and was putting my old computer (3.0ghz P4, Asus P5LD2, 7600GT, 1 gig Ram) in my girlfriends office and have been having issues. I am not entirely sure what is going on, so I wanted to run it by you guys to make sure.
I have always had temperature problems with the P4 (getting upwards of 63 C while under moderate load). I never overclocked it, and ran everything at stock voltages. When I put it upstairs, it shut off on me. I pee'd a little and checked BIOS and it said it was 76 C! I thought, this can't be right... it must be a false reading. It had been sitting upstairs for a few days and it had only been on for about 5 minutes. The temp couldn't get that hot. Needless to say, things got worse. Now I can't even get to the BIOS because when I turn it on, it just continually cycles. The only reason I think it might be something other than a crapped out prescot is that the wall plug it is in now is a 2 pronger with an adapter. I was wondering if the problem might be in the power and the temperature is just an anomalous reading. I am willing to buy another old chip to replace it (it will be a word processing internet machine from now on), but I don't want to plug any money in it if it is something else.
Paul
Message edited by Jake_Barnes on 09-15-2008 at 05:26:18 PM
Sponsored Links
try re-installing heatsink and a fresh coat of thermal paste into cpu
------------------------------ Intel Pentium 4 630 3.0Ghz Shuttle XPC SB81P(intel 915G)
Patriot Dual Channel 2GB DDR400: Raid0 640GB 2pc WD3200AAJS
Powercolor ATI Radeon HD3870 PCS 512MB DDR4
http://valid.x86-secret.com/cache/banner/414710.png
Reply to goonting
- 0 +
I will give it a shot, but do you think it is too late? I thought I probably fried the chip like a tasty hotwing.
Reply to lca806
P4 chips usually steps down to keep it cool... and boards auto shutdown when its hot... unlikely to get fried right away.. Haven't you re-applied thermal paste in years?
Reply to goonting
Try different memory if you can.
Could be a power supply going bad.
------------------------------ Google is your friend and Bob's your uncle
Reply to evongugg
Get a ginormous heat sink/fan assembly for it.
I used a Thermalright XP-90 and a Vantec Tornado fan in the past for my old Prescott that my folks have now. It's loud as hell, but it keeps the temps under 50C idle...
Reply to killerb255
- 0 +
I have a fairly decent heatsink fan on it (better than the original heat sink). I just tried reapplying thermal grease and reseating it but it didn't help. It comes up with the ASUS screen and then goes black and does it again until I get depressed.
The power supply is a generic 450 watt that came with the case (Xion) - It was my first build and I didn't know better. Is there a way to test the PSU?
I will try plugging in some memory to see if that is it.
Thanks for the help!
Reply to lca806
- 0 +
Components can shift while moving a computer. Try reseating memory, cpu, and the expansion cards "modem, NIC, etc..."
Reply to BadTrip
- 0 +
I tried reseating everything and turning it on again (I thought I was onto something because my SATA cable has always been loose). But it didn't work. I think I should probably just try getting a new chip for it and give it a shot. They aren't too expensive at the egg. What heat sink should I get for it?
Reply to lca806
- 0 +
UPDATE
OK.... so I bought a new P4 off of ebay for $30 just to try it out. You were right.. I was wrong. That didn't do it. So I went in and tried everything. Changed out memory - no go... the whole she-bang. Then I realized... I am an idiot. While my box was out, I threw in an old hard drive from a different computer (an extra 30 gigs can't hurt!). I plugged it into the motherboard, but I didn't do anything else (like set the jumper to slave, plug in the molex, you know, all the things any self respecting system builder would do). Unplugged the thing and voila... turns on no problem (although now it says that my CPU fan is malfunctioning eventhough it is working, so if anyone knows what is up with that... that would be great).
Just thought I would share.
Reply to lca806
- 0 +
OK... this is becoming a lot like that movie with Atreyu and Falcor. Sorry, I like obscure movie references ("BE CONFIDENT!" )
So I THOUGHT it was fixed because it turned on and worked normally for the next 4-5 bootups. Now it is doing it again. Same symptoms as before. Is this indicative of a power supply? It wouldn't surprise me since it is a XION generic PSU.
As for the CPU fan, that was a big my bad. I didn't have my glasses on when I was plugging things back in and I accidentally put it into the Chassis Fan slot.
I am close to just buying a cheap mobo/cpu and new PSU and be done with the problems.
Anyway, any help I can get so my girlfriend doesn't have to use my good computer to play mahjong for 6 hour marathons would be very appreciated.
Reply to lca806
There are 464 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 gpfear won the Freshman badge
  • 01:00 Conrad925 won the Freshman badge
  • 01:00 skythra won the Freshman badge
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
