Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Is this a good power supply?.........(inside)
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Is this a good power supply?.........(inside)
http://www.antec.com/ec/fr/product [...] odID=04660
for this system :
- P5N-D
- E8400 @ 3.6GHW
- 8800 GTS 512
- 2 GB ram
- 1 HDD 7200 rpm and 1 dvd drive
- 2 case fans
Curently I own 1 8800 GTS but i want to get another one and I think this pwoer supply can't handle 2 8800 GTS 512
http://en.toppreise.ch/desc_124859.html . Can it ?
Should I try first and then chance it?
How can I find out if my computer is underpowerd?
What happens if it's underpowerd?
Sponsored Links
That is a very good psu it will handle 2 8800gts maybe even 3.
if its underpower it will run unstable or not run at all.
------------------------------ intel core 2 quad q6600 @3.2ghz msi p6n diamond (X-FI Extreme sound) 6gig of OCZ+CoRSAIR oc 900mhz Nvidia gtx 260 sli @ 730/1465/1250
Lite-On Blue-ray Western Digital 7200rpm 500gb Antec 500 Earthwatt Window vista 64-bit
Reply to invisik
And what do you mean by ,unstable'.It will damage the components ? What will it happen?
And can the PSU I own now run 2 8800 GTS this one:
Reply to yetyhunter
- 0 +
usually a psu has a safe feature im pretty sure antec does so most of the time components dont get damaged but theres a slim chance it will. when i mean by unstable the computer will freeze up restart and such. that psu isnt good at all. for 600w it has low amps on the 12v rails. i mean it should work but its cutting it close. u can give it a shot and see if it runs.
Reply to invisik
But my psu has a safety feature right?
Reply to yetyhunter
- 0 +
well its not a good brand i cant promise nothing will happen. usually like 90% it will just restart if it doesnt have enough power but there is a small chance it can take something out. if it were me i would give it a shot but hey its me. But if ur not wanting to take the chance just buy a new psu.
Message edited by invisik on 09-03-2008 at 01:21:32 AM
Reply to invisik
The EarthWatt is Antec mid to lower end PSU, personally i would look at the Trio, Neo Power or Signature series they use better components. However, that earthwatts should run 2x8800gts but its cutting it close.
EDIT: Further investigation reveals the Earthwatts has stronger 12v rails than i thought, it should be enough. If you want something better in the Antec only go the Signature or Quattro
Message quoted 1 times
Message edited by chookman on 09-03-2008 at 01:35:51 AM
------------------------------ "This thread made me strap on my lolerskates and head for my roflcopter."
Reply to chookman
- 0 +
its a really strong psu. look at my setup.
Reply to invisik
you are runnig 2 GTX 260 with a Antec 500 watts PSU .
Reply to yetyhunter
- 0 +
yup and there both oc same with my quad core. so since ur planning to use 2 8800gts im pretty sure it would work.
Reply to invisik
Antec EA650 good, but Corsair 650TX much better
Reply to jamesgoddard
[quotemsg=1856683,12,54488]Antec EA650 good, but Corsair 650TX much better[/quotemsg/]
Corsair has only 1 +12v rail of 62 .Antec has 3 rails 2x22A and 1 x25A .Wich is better 1 rail of 62A or 3 rails of 69A?
Reply to yetyhunter
- 0 +
single rail is slightly better then split rails.
Reply to invisik
The combined output of the three +12v rails on the Antec is 45 amps, the single rail on the Corsair can supply 52 amps.
------------------------------ q9650 @ 4.050 | Asus Rampage Formula | 2x2 & 2x1 Corsair Dominators | WD Black 640 x2
EVGA GTX260 Core216 @ 686/1479/1103 | Antec TPN 750
Reply to Delluser1
Do you think I will be able to run 2 8800 GTS 512 with 1 +12V of 15 and a 2nd +12V of 16 = 31 A = 372 Watts? Right?
http://www.evga.com/products/moreI [...] s%20Family.Look at the power requirements.
Only 30 A required for 2 8800 GTS 512
And here http://www.atomicmpc.com.au/forums [...] c=7&t=9354
2 8800 GTs 512 using 217 watts on full load.
What do you think sould I be able to run them?
Reply to yetyhunter
There are 1137 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
