Power Supply Failure 2 in row?
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Power Supply Failure 2 in row?
Hi folks,
I recently upgraded my PC and im getting terrable problems with Powersupplies. The one that i had was a good brand and make or so i thought the Corsair hx 620 Watt. I had my PC setup all cables connected properly and nothing...eventually i found out that the Previously working PSU was dead. It cost me quite alot at the time back in march. Only got an RMA number today so its gonna take a while to get a new one.
Anyways so i go buy a new one in the meantime a 600 watt "Artic Jeantech" which i must say looks cheaply made and sure enough all cables connected and nothing PSU dead again a brand new one.
Now either im stupid or terrable unluckly. And yes im wearing static protection. Ive never had problems like this before with any PC Upgrades can anyone help.
The motherboard i have is a good make and i paid almost double so it would be of good quailty its a "Gigabyte MA790FX-DS5".
Ice checked both power supplies with the "Paper clip" method and there completly dead. Ive tried plugging them in with other cables and in different sockets around the house.
The amazing thing is that the motherboard CPU and everything connected to it atm is running on a 450 Watt Jeantech PSU. Which i had kept as it has a problem in that it just turns on the mobo. This piece of crap PSU should be in the Bin but its running things atm. I know its not powerful enough but its all i have atm until i get another new PSU tommrow.
So am i unlucky or is something wrong somewhere?
Sponsored Links
need full spec of ur rig.
------------------------------ intel core 2 quad q6600 @3.2ghz msi p6n diamond (X-FI Extreme sound) 6gig of OCZ+CoRSAIR oc 900mhz Nvidia gtx 260 sli @ 730/1465/1250
Lite-On Blue-ray Western Digital 7200rpm 500gb Antec 500 Earthwatt Window vista 64-bit
Reply to invisik
AMD Phenom 9850 (64 X4)
4 gigs DDR 2 PC 6400 ram
ATI 4870 512 mb PCIE
WD 1TB Western Digital SATA 2
Emprex DVDRW
120 Samsung IDE
400 Samsung IDE
250 Samsug IDE
Conceptronic SATA/IDE Combo Card
2 System Fans
and of course;
450 watt Jeantech PSU
Is it possable that 600Watts is not enough for my setup? And if so how come a crappy 450Watt PSU can keep things running?
Whats causing the PSU's to Fail? Was i just unlucky?
Reply to irishbloke
- 0 +
Problem might not be the cpu,could be the whole setup.Im adventurous so i keep things running and just plug and unplug till it boots up.Always cautious about the static thing but, I found alot of power suppplies arent junk ,there just not properly seated in the right order.Swap the cables around while its running hitting the del key until it shows the hd,cd,sata whatever.Always works for me, 5 years with this psu and it still fly's.Like I said ,had to do some messin around with it bit it isnt junk.Even got it overclockin.Peace!~
Reply to slick
- 0 +
I highly doubt that generic PSU can have enough juice for this machine.
Reply to AKM880
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Power Supply Failure 2 in row?
There are 1185 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
