Blackout and Power Supply?
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Blackout and Power Supply?
Okay, here's the situation, I built my computer 3 weeks ago, been running great and smooth
Yesterday, when I got home, my computer was off (I left it on for downloading) and was making a o.o face
I tried to turn it back on, no response, after a short while, I realized there had been a blackout, so I opened up my computer and see what's wrong, the motherboard lights were flashing, my brother said it's probably the power supply so I took it out and was preparing to take it for replacement, but then I wanted to try again while waiting for the car if it's really the power supply, so I plugged the motherboard to the PSU, and bam! It worked! (Without the bam sound) I was happy I didn't have to go and replace it.
Well... today... while I was watching some video, what do you know, another blackout... and... the whole problem is happening again... I opened the case, checked out the stuff, no good, the motherboard's lights are flashing again, I then gave the PSU a good pat on the back, and the motherboard's lights were good again...
I just want to ask if it's really the PSU that's having the problem or other stuff, and if it's the PSU, should I go back and replace it? (Don't know if they will replace it for me since it's technically working...)
Thanks!
Edit: Forgot to put specs
Processor: Intel box core 2 DUO E8400 3.00Ghz
Motherboard: ASUS P5Q3 Deluxe/Wifi-AP
Memory: OCZ DDR3 2G 1333MHz
Power supply: Antec 650 Trio
Graphics Card: Radeon 3780x2
Message edited by Vaye on 09-03-2008 at 07:24:51 PM
Sponsored Links
Looks like the PSU died. I suggest getting an UPS (Uninturrupted Power Supply, aka Battery) so this never happens again (APC makes good ones).
Reply to IH8U
- 0 +
While I would definitely agree that getting a UPS is a great idea, I'm not sure you have a problem. If you turn the PSU off with the rear switch, wait about half a minute, and turn it back on, does everything work normally? I suspect that what you are seeing is a safety feature of that PSU that keeps it shut off to protect vs. a potentially yo-yoing input power source until a person resets it.
------------------------------ There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
AT least get a surge protector of some kind before you short your system out...
Reply to gamerk316
- 0 +
I am sure I turned it off while I was taking it off the computer, and when I gave it a light whack in the face, the motherboard's lights stopped flashing and started working again
I will look into that before I replace it though
Reply to Vaye
I agree with jtt283, sometimes the power supply will just need a full reset after a power outage (protecting itself)
If you have that many power outages definetly get a UPS
------------------------------ "This thread made me strap on my lolerskates and head for my roflcopter."
Reply to chookman
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Blackout and Power Supply?
There are 957 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
