Tom's Hardware > Forum > CPU & Components > CPUs > cpu temp / power consumption
hi,
1) how do i check my pc temp without going into the bios. i have a q6600.
2) is there anyway to see how much power is currently being using by ur pc? while running games or other apps? i just want to see the consumption
are there 3rd party software or sometin for these?
thanks in advance.
Sponsored Links
1) Which temperature do you want to check? Since you mentioned your cpu, I'll suggest Realtemp to monitor cpu temps.
2) There are websites that can estimate the power consumption, but for something more accurate, you'd need something like this: http://www.amazon.com/exec/obidos/ [...] ghorror-20 It doesn't have to be that exact one, but that's the type of tool you'll need.
Here's a site if you just want a general idea: http://extreme.outervision.com/psucalculatorlite.jsp
Reply to br3nd064
- 0 +
thanks alot. yea i got real temp works out good.
meh i was hopin there was some 'real-time' application which told me power consumption. but thats fine :)
Reply to demon1
There are 696 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
