If I take a digital coaxial cable and connect it from the motherboard to a 5.1 receiver, will I get true surround sound from my speakers or will they all be producing the same exact audio?
2 channel sources will NOT play in surround. You have to use either a filter on your amp or on your card. However getting your source(the pc) to convert 2 channel to surround through a digital connection like spdif or fiber is only a feature you can get on pro devices. The xfi series can do it but only with 3rd party apps. Basicly what I am saying is you can NOT get surround over a true digital connection in this case unless your amp supports it with some filter. Even then its fake. Nearly no sound cards will convert 90+hz to surround via a digital connection. You are stuck with analog.
Movies recorded in surround ect.. will play providing you have the codec ect.. for the hardware to do it all.
Games are another story. There is no game in creation that will play on any desktop hardware in surround sound while transmitting digital surround. You are stuck with analog when gaming or stereo sound when using digital. Some specialty systems claim its digital surround like the logitec systems but in trueth its just converted analog thus poor sound quality. In otherwords 99% of the time its stereo when gaming or analog bottom line.
Simple answer: If the source material is surround (5.1, 7.1, DTS, whatever), then the digital cable will deliver it to your receiver. If the source material is stereo, the digital cable will deliver a stereo signal, which your receiver can then process using it's own logic.
------------------------------Which Chip? Well, it depends on which set of thieving b@stardz you choose to support: The ones who use insider trading to enrich themselves while running their company into the ground, or the ones who illegally pay vendors to not support the first group.
Reply to Scotteq
REALLY short answer: Yes. DOOO IT!!
Yeh, but you forgot about "Live" sounds such as games, which are usually 5.1, yet go out over the coaxial cable as stereo because the audio codec doesn't have the capability of combining them to a single digital signal.
I think that the new X-fi Titanium series can do the digital encoding on the fly (I could be wrong though)
EDIT: Yeah, it looks like they support Dolby Digital Live encoding. I think they're the only ones though.
Not the only ones, in fact Creative is several years behind everyone else. C-Media has had a DDL sound chip for over two years (with several brands of cards on the market), an even the old nVidia Soundstorm audio controller (nForce 3 over 4 years ago) could do on-the-fly digital encoding.
Just to expand a little on what Crashman has said.
Unless you have a sound processor to do DD Live or similar (you will need a c-media equipped card with a CMI8770 or 8768+ or equivalent), you will only get 2 channels from games over s/pdif.
Creative are NOT a leader in this field as they prefer to rely on their proprietary EAX technology.
------------------------------GA-X38-DS4 (BIOS F3)||E8400 C2D (3.6GHz)||2x 1Gb Crucial Ballistix DDR2-800 4-4-4-12||320Gb WD Caviar||2x 750Gb WD Caviar||Cooler Master Real Power Pro 750W||2x HD4870 512Mb(Crossfire)||HT Omega Striker 7.1
Reply to jay_l_a
