My New System build
Forum Homebuilt Systems : New System Build - My New System build
Hey guys, I've been thinking of buying a new system lately and this is what I've came up with. Please comment on what you would like to see different or what I can change.
Case --- http://www.newegg.com/Product/Prod [...] 6811129021\
MB --- http://www.newegg.com/Product/Prod [...] 6813136038
Power Supply --- http://www.newegg.com/Product/Prod [...] 6817341002
Ram --- http://www.newegg.com/Product/Prod [...] 6820231122
CPU --- http://www.newegg.com/Product/Prod [...] 6819115037
Hard drive *need advice* http://www.newegg.com/Product/Prod [...] 6822136011
Monitor --- http://www.newegg.com/Product/Prod [...] 6824255001
Cooling --- http://www.newegg.com/Product/Prod [...] 6835100007
http://www.newegg.com/Product/Prod [...] 6835186134
OS --- http://www.newegg.com/Product/Prod [...] 6832116488
CD/DVD Drive --- http://www.newegg.com/Product/Prod [...] 6827106087
Video Card --- My friend is going to give me his 8800GTX unused for $190. Is this a good deal, or should I go for a 9800GTX?
Total Price : $1,576.89 w/ the Video Card.
Thanks for the help guys.
Sponsored Links
I would get a SATA DVD Drive.
Take an HD 4850 as your video card.
Pass on the Raptor X and get that 640GB hard drive. It's one fast hard drive.
Consider a 650W Corsair power supply.
Reply to SanjiWatsuki
Your system looks great!!!
- Agree about getting a SATA DVD drive
- That is a deal on the 8800GTX but the 4850 is newer and may be the better choice.
- I would personally save some money and just forget about the raptors - I think a normal SATA drive would be the better way to go.
- Keep the OCZ Power Supply
Overall very nice!!! and WELCOME TO THE FORUM!
Reply to helios2052
- 0 +
That monitor has only 8ms response time. For gaming, you'll want 5ms or better.
There are lots of choices out there, and many of the panels are made by the same company anyway, but you might like this 2ms response, 22" Samsung, for $300 after MIR:
http://www.newegg.com/Product/Prod [...] 6824001273
------------------------------ There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
- 0 +
If you write the names of the parts near the links you'll make it easier for people to help you.
Check out the GA-EP43-DS3L, it has PCI-E 2.
8800GTX at $190 is a great deal, if you trust this friend. If in doubt, get a HD 4850. 8800GTX, 9800GTX, and HD 4850 are all very close, with HD 4850 winning some benchmarks.
Get a WD6400AAKS instead of that old Raptor.
Get a SH-S203N and you won't have to deal with IDE cables and jumpers.
Message edited by aevm on 07-11-2008 at 09:17:38 PM
Reply to aevm
- 0 +
TigerDirect is selling 9800GTX for $199. Your friends 8800GTX has just got expensive.
Also, your mobo is Intel and both GTXs are nVidia, preventing you from SLI/CF in the future.
If you have plans for multiple video cards, you either change your mobo or (preferably) change your video cards.
Should you stay with Intel chipsets, +1 for aevm.
Reply to galta
Tom's Hardware > Forum > Homebuilt Systems > New System Build > My New System build
There are 1268 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
