Yes No
Ads
Help choosing Card
Forum Graphics & Displays : Graphics Cards Help choosing Card
Related Content
Can't find your answer?
Ask!
Hey guys I want to upgrade my PC'S Graphic card and also add a set of new fans and some Ram.
I currently have :
M/B: Intel D975XBX
VGA: Evga Geforce 7900GTX
Ram: 2Gb Corsair XMS2 800Mhz
Processor: Core 2 Duo X6800
Power Supply: Thermaltake PurePower 680W.
O/S: Vista / XP (for games)
For some reason my graphic card is overheating and when I play need for speed Pro Street the screen begins to blur and i see alot of triangles and stuff.
I really want to be able to max out all games and have them running smooth on my system.
What do you recommend? I am looking for a VGA card around $300.00.
What can you recommend for the fans as well? I have a stock intel Cpu fan and Two thermaltake fans that came with my case.
Reply to sharkextreme
4870 or 260 gtx. i would buy 4870 .
Reply to lukuks
+1 4870 or GTX 260
If you keep your eyes open, you can find a GTX 260 for as low as $230.
A 4870 will run you $255.
For the CPU cooler, take a look at the Artic Cooling Freezer 7 Pro.
Excellent cooling on the cheap.
The RAM is a little more difficult to recommend.
Look for a 2Gb set (2x 1Gb sticks) of DDR2 800 with the same timings and voltage specs as your current set.
------------------------------ If the automobile had followed the same development cycle as the computer, a Rolls-Royce today would cost $100, get a million miles to the gallon, and explode once a year, killing everyone inside.
PSA
Reply to outlw6669
You can turn up the fan in your old card with Rivatuner.
------------------------------ I am learning here!
Reply to evongugg
- -1 +
+1
Reply to homerdog
Hey guys thanks for the posts!!!
Will these PCI -e 2.0 cards owrk on mY PCI -e 1 motherboard?
Yes, PCIe 2.0 is fully backwards compatible with PCIe 1.1.
PSA
Reply to outlw6669
Okay kewl thanks!!!
Will organize to buy 260 gtx.
With my specs and the new fans plus 2 more gigs of ram and the new video card. Should I be able to max out pro street?
Yes, the GTX 260 is vastly superior to your 7900GTX.
You should have no problems maxing out NFSPS.
PSA
Reply to outlw6669
- 0 +
^ AND HD 4870 IS MUCH SUPERIOR TO THIS TWO
Reply to pulasky
^^hence even more vastly superior than 7900GTX....best upgrade for the money
------------------------------ AMD Phenom II x4 945; ASUS M4A785D-M PRO, AMD 785G;
xfx ATi 5770; 4GB DDR2 800bus; 1TB HDD
X-Fi XtremeMusic; 420W Thermaltake TR2 PSU
Reply to sarwar_r87
Okay so between 4870 and gtx260 which one is better?
- 0 +
4870 is better, but you can wait for the Diamond's XOC Black Edition and u can do some major overclocking to it
its about 315 or something like that
Reply to xech
Thanks Guys guess ill go with the 4870!!!
Will let you know how the system runs when I buy it!
Okay quick question about the ram now!
If I buy a next set of XMS2's but with a lower latency and timings will they still work on my system?
It will run at the slower RAM's latency but it should work.
You will have to manually configure your BIOS settings and test using memtest to make sure everything stays stable.
PSA
Reply to outlw6669
- 0 +
lol he doesnt need a 4870 to play nfsps...
Reply to V3NOM
Tom's Hardware > Forum > Graphics & Displays > Graphics Cards > Help choosing Card
There are 1594 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
I need a new video card - Help?
By Pinhedd, 1 hour ago:
6670 1GB hands down. The 6570 is less powerful and has inferior GDDR3 RAM which is vastly...
Best offers
Top experts
