First off, I don't have much experience in hardware installation, aside from basically installing new hard drives and extra RAM. As a C++ and PHP programmer, I'm more of a software guy. But this week I decided to build a new desktop. I have purchased components for a new PC from Newegg (excluding a case and DVD-RW drive, which I already had). Motherboard, power supply, video card, RAM, hard drive.
After assembling everything, I was greeted with an unhappy surprise: the PC will not power on at all. I have ensured that the power supply switch is on, of course, no luck.
Here is the power supply (Corsair 750W ATX): http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
And here is the motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813130168
I believe the cause to be that I may have missed a cable somewhere. I have checked and double-checked the cables, but to no avail. Here are the cables I checked from power supply to motherboard; please let me know if I missed any:
- 24-pin cable from PS to MB
- 4-pin connector from PS to MB (power supply is actually an 8-pin connector, but the manual says to "remove" one half if the motherboard is a 4-pin one. So, I plugged the first half of the 8 pins into the 4 pin connection slot - could this area have something to do with it?).
- Power supply jumper cable from case to motherboard
This is very frustrating. I spent ~half an hour or more googling for troubleshooting guides, and couldn't find any solution that seemed to apply except for the cables, which appear correct.
