Problems with a LG hdd hxd2 320gb
  • LG
  • Computer
  • Hard Drives
  • Storage
Last response: in Storage
November 17, 2009 4:46:01 PM
I was wondering if there was anyone who could help me. I have an LG hdd hxd2 320gb and when i plug it into my laptop it makes a soft sound like it is trying to read but it makes that sound then a beep, it dose this a few times then stops and will not read. it dose not read on my computer nor on another computer. i dont know what it could be it is almost full and i dont want to loose everything that is on it. i have a lot of personally important stuff on it. please if there is any one that can help please do. thank you.
More about : problems hdd hxd2 320gb
a b G Storage
November 18, 2009 12:57:18 AM
Does it come with a detachable cable? Try using another USB cable if that's the case.
m
l
November 18, 2009 9:23:14 AM
it dose have a detachable cable but the cable has dual USB plug that go into the computer. I will try that but just in case. any other ideas? thanks.
m
l
December 15, 2009 1:51:33 PM
I have the same problem :(  did you solved? help me please!!!!!
m
l
December 15, 2009 2:15:10 PM
sorry i have not solved it i am haveing som it guys fix at work. sorry
m
l
Anonymous
a b G Storage
October 21, 2011 2:53:14 PM
I had this problem with one of my laptops. It worked OK with the other. What I realized was probably insuffiient power coming from the laptop. That's why you have two USB plugs, one for additional power only.
solutions which come to my mind:
1. use another computer ;-)
2. plug both USB plugs to two separate USB sockets (if you have more than 2 use most distant ones
3. use powered USB hub (one with separate power source)
Hope this helps
Tom
m
l
January 8, 2012 6:02:04 AM
same problem with my hxd2 320gb,it suddenly stops
m
l
