hi when the case says it can support 3 optional 120mm fans...does that mean i cant fit in 80mm fans?
does it have to be 120mm? if i can put in 80mm will it be too much off a problem? do i need extra 'parts' to make em fit in the 120mm space?
thanks in advance
thanks in advance
