Tom's Hardware Forums » Homebuilt Systems » New System Build » Building new system, need some advice
Add a reply
 Word :   Username :
Bottom
Author
 Thread : Building new system, need some advice
Profile: stranger
More Information
Im working on building a new system, i have some ideas on what to use but need a little more advice. I want to have some balance but mostly use it for gaming. I want to keep this system for a long time, but it would be nice if i could upgrade the processor and other components without changing the Mobo every year. I would like to keep the budget to $1200-1500 Heres what i have so far.
Case: Antec Solo mid tower
Mobo: ASUS P5E Deluxe
CPU: E8400
Heatsink: ARCTIC COOLING Freezer 7 Pro (if it will fit, anyone try it with similar setup?)
Video card: evga 8800GT
HD: 500GB, not sure weather to use WD or Seagate just want it more quiet than fast
PSU: preferably Antec not sure how many watts are needed
RAM: not sure gskill or corsair?
forgot to mention i would like it to OC as much as possible
thanks for any suggestions
Message edited by steve345 on 07-12-2008 at 06:22:45 AM
Related Pr oduct
Profile: member
More Information
"but it would be nice if i could upgrade the processor"
This is not going to happen-seeing as how the new intel chips coming out later this year, and through next year won't be using the same motherboard socket. I hate to break that to you.
Message edited by effel on 07-12-2008 at 06:33:48 AM
Profile: member
More Information
yea i would suggest just buying budget parts. maybe get a cheaper mobo. gfx card is good. cheaper cpu OC it a little may be? i would suggest 600~700 watt PSU that is energy effeciant and has a long warranty. i know seasonic has some nice ones. thats one thing that can change from PC to PC without worrying about "upgrade" unless you plan to go sli or something then you might need more juice.
For HDDs, I have used WD's they are pretty good. just dont let them overheat or just make sure you have your data backed up, worst mistake you can make is not having a backup.
For Ram, i got some nice cucial memory ddr2-800 4x1gb for 50 bucks. on rebate. stuff is good and cheap.
My advice, Go budget and just rebuild in a year or two depending on how technology advances "new sockets etc." I'm not making the same mistake of spending all my money on a high end system that gets outdated too fast. Atleast this way you have a fully functional PC to sell for decent cash by the time of your next upgrade.
Add a reply
Google Ads
