Funny smell from new power supply
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Funny smell from new power supply
So I installed a new antec earthwatts power supply, and it has a funny smell coming from it. It is almost a mix of burning plastic and the smell you get from an oxygen mask, is this normal?
Sponsored Links
All new things smell when first turned on..
But the definition of how much smell is obviously stated by the alarm that you have..
I would personally take it back if your not happy with it.
Reply to Hellboy
use it for like 1 week max the smell should be gone. dont go and sniff those smell make sure room ventilation is good. those smell from the factory will cause cancer in a long term.
Reply to iluvgillgill
Mmm... new plasticky burning smell. Well it's one of two things, its the new smell and certain factory residues are being burned off, or your power supply is buring up ^_^. Really though it should be gone in two days or so. Check to see if your voltages are flucuating just to be safe.
------------------------------ Playing X-Men Origins: Wolverine Phenom II X4 955 | GIGABYTE GA-MA790X-DS4 | 4GB Mushkin DDR2 1066 | Plextor 760A| 2x 3850 512M CF| WD 1TB Black| Fortron Blue Storm II 500W | APEVIA X-Dreamer Black | Win XP Pro & Vista Buisness 32bit
Reply to megamanx00
You get cancer from anything these days.
You get cancer if you stay in your own home and try and avoid everyone and everything.
------------------------------ "This thread made me strap on my lolerskates and head for my roflcopter."
Reply to chookman
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Funny smell from new power supply
There are 1321 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
