Hi All,
I had a little accident today with my Buffalo external hard drive. While working at my desk at home I accidently knocked the drive with my arm and it fell on to the carpet. Now whenever I plug the drive into my laptop, I see it in Explorer as before, but when I click on it the laptop hour glasses, and eventually I get the message "The disk in drive E is not formatted. Do you want to format it?".
80% of the data on the drive has previously been backed up, but there are some recently moved files on it that I'd really like to recover.
I can't afford to give it in to a shop, and even if I could I would be some what concerned as the drive has files with personal information on them... so basically I need to know what my options are?... is there any software that can be used to recover the data without the drive requiring dismantling in some labs?
One thing my brother tried for me was to remove the drive from the Buffalo casing (which turned out to be surprising easy) and insert it into another external SATA drive casing... but still no luck... the drive continued to behave as if it needed formatting.
Anyway, I would appreciate some advise, even if it's just to say... "take it into the shop else bin it!!"... in which case I will have to bin it as I really am concerned about all the personal and confidential data on the drive, plus it may be too expensive for me to afford anyway.
Many thanks
Sharon
Many thanks
Sharon
