Rahbot
231
R U talking about the Evercool Fox-1 SB-F1 PCI System Blower?
If so they are just like any pci slot case fan you can put in your system unless your going for something else in the same lines as that.
leo2kp
I just put one in an old Dell and it does pull hot air out, but like Conumdrum said, you need a good case design to really benefit from lots of airflow. I can't see any reason why a PCI cooler would be ideal except when you absolutely need it as they are usually sitting too low in the case to make a huge difference (heat rises).
