Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Help! Several problems with first build
Forum Homebuilt Systems : General Homebuilt - Help! Several problems with first build
I just put together my first system and it runs well, but there are a couple of minor problems that you might be able to help me out with.
Necessary system info:
CM690 Case
Gigabyte EP35 DS3L
Windows Vista Premium 64
The problems:
1. I am unable to use the headphone or microphone jack on top of the case. I think I plugged everything in correctly, but I am not sure which cable corresponds with those.
2. I am unable to switch between headphones and speakers mid-game. I must quit the game, switch cables, then restart the game. Remember that I have to plug the headphones and speaker into the same port because the top one doesnt work.
3. I cant get my microphone to work at all, even when plugged into the back of the case. It works fine on my other computer. I think this may be a vista issue, but I dont really know.
Any help is appreciated.
Message edited by brentster10 on 07-14-2008 at 04:27:50 AM
Sponsored Links
Have you installed the Realtek utility that comes with your mobo CD?
Reply to smalltime0
There are 459 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
