Tom's Hardware > Forum > Graphic & Displays > ATI > ATI Radeon HD 3450 Resolution help
Forum Graphic & Displays : ATI - ATI Radeon HD 3450 Resolution help
I just installed the card but it won't allow me to set the resolution to 1680 x 1050 which is neede for my monitor -HP 22w. It olny offers 1280 x 1024 or 1600 x 1200. Any suggestions?
Sponsored Links
installed the correct drivers???
Reply to smyffalis
Bit more info please AGP/PCIE ? what drivers did you use, is it a clean install etc.
Mactronix
Reply to mactronix
There is one thing you need to check. If you have a DYI computer, is the express graphics slot active on the motherboard in setup. Even after I corrected that setting, I still couldn't get anything more on the DVI connection that 1024x768. What fixed the problem for me was to disable the 2nd display clone in ATI Catalyst. Now I have full resolution available of 1650x1050 in Vista SP1. It was interesting that when I installed Ubuntu 8.10 (dual boot) and used the restricted drivers, I got the full resolution automatically.
Reply to bobemarks
There are 661 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
