Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > 4870 power question.
Forum Graphic & Displays : Graphics Cards - 4870 power question.
I'm interested in buying a 4870. My power supply, while being a 550 watt/35 amp one, only has one 6 pin pci-e power connector.
Would it be alright to use a converter from two molex connectors to a 6 pin connector for the second one? Or would this cause instability?
This is my power supply. I know Rosewill is considered poor quality, but it seems fairly solid to me, and I think it should work. As long as the converter is an okay idea.
I think I'm going to try it with this power supply first, and if I have problems get a new one. But I just wanted to get your guys opinion first.
Sponsored Links
it comes with a convertor in the box , so just use that :) , so answer to your question , yes its fine.
Reply to samuraiblade
Ok, that sounds good then. I just wasn't sure if it was a bad idea, because of different power cables using different rails within the power supply or whatever... Like it might not use the 12V rail because it's the wrong cable. I just don't know too much about power supplies, so I wasn't really sure.
But I thought it would be fine, and your answer has confirmed that. Thanks for your help.
Reply to yadge
There are 1353 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
