You can't. Everytime you charge an Lithium ion battery it loses a tiny bit of capacity - Over time the battery will become less and less efficient in storing energy. I'm guessing you've had the battery a while?
You're options are to either buy a new battery, keep the laptop plugged in, or buy a new laptop (obviously with a new battery).
Your options are to either buy a new battery, keep the laptop plugged in, or buy a new laptop (obviously with a new battery).
Did you buy it used? Old batteries lose capacity over time - all you can do is get a new battery. Of course, if that's a new battery, something is seriously wrong.
It's brand new! I just got it and had two before it that had the same problem.
I sounds like a hardware fault else where. Perhaps a dodgy power supply connection isn't providing sufficient juice to charge the battery? I don't know, but it is VERY unlikely to receive 3 defective batteries - unless it was a bad batch.
By power supply, are you referring to the external transformer or something inside the laptop itself?
Hi spork985,
Try to fully discharge your hp dv9000t laptop battery and then charge it with an Ac adapter.
More info available at : http://www.power-batteries.net/notebook/hp.html there you could find some helpful tips for hp laptop battery.
Good luck!
