Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > What is the best 1200W Power Supply?
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - What is the best 1200W Power Supply?
I have been looking at different 1200W PSU and was wondering what you think is better between.
1. SILVERSTONE ST1200 1200W Power Supply
http://www.pricebat.ca/productimage/normal/10067973.jpg
Output:
+3.3V@40A,+5V@40A,+12V1@28A,+12V2@28A,+12V3@20A, +12V4@20A,
+12V5@20A,+12V6@28A,-12V@0.8A, +5VSB@6.0A
Crossfire support:
2. Toughpower 1200W Power Supply
http://www.techfresh.net/wp-content/uploads/2007/02/thermaltake-1200w-psu_1.jpg
Output:
+3.3V@30A,+5V@30A,+12V1@20A,+12V2@20A,+12V3@36A,
+12V4@36A,-12V@0.8A,+5VSB@3.5A
Crossfire support:
3. Tuniq Ensemble 1200W Power Supply
http://computershopper.com/shoptalk/Tuniq%20Ensemble%201200.jpg
Output: +3.3V@30A,+5V@30A,+12V1@20A,+12V2@20A,
+12V3@25A,+12V4@25A,-12V@0.8A,+5VSB@6.0A
Crossfire support:
4. OCZ 1200W POWER SUPPLY T12W +12VDC SLI CERTIFIED PCIE 24-PIN DUAL
http://www.pcpower.com/images/products/b/1200W_TC_3835.jpg
Output:
+3.3V@24A,+5V@30A,+12V@90A,-12V@0.8A,+5VSB@4.0A
Crossfire support:
5. COOLMAX CUQ-1200B Outlets 1200W Power Supply Retail
http://www.tweaknews.net/reviews/coolmax_green_power_1200watt_power_supply_review/img/1.jpg
Output:
Crossfire support:
6. ePOWER EP-1200P10-T2 1200W Power Supply
http://c1.neweggimages.com/NeweggImage/productimage/17-101-022-11.jpg
Output:
+3.3V@30A,+5V@30A,+12V1@20A,+12V2@20A,+12V3@20A, +12V4@20A,
+12V5@20A,+12V6@20A,-12V@0.8A,+5VSB@6.0A
Crossfire support:
7. Gigabyte GE-MK20A-D1 ODIN Pro 1200W Power Supply
http://www.sybaritic.co.za/store/images/GE-MK20A-D1.jpg
OUTPUT: +3.3V@30A ,+12V1@20A ,+12V2@20A, +12V3@36A ,+12V4@36A,+5V@30A
-12V@0.8A +5Vsb@3.5A
Crossfire support: Ready
8. NSPIRE 1200W PS NSP-PUC1200V ATX V2.2 EPS V2.91CABLE MANAGEMENT80+
http://www.atacom.com/html3/POWS/graphics/POWS_NSPI_A2_05_more.jpg
Ouput: +5V@30.0A,+12V1@20.0A,+12V2@20.0A,12V3@36.0A,+12V4@36.0A,+3.3V@30.0A
+5vsb@3.5A
Crossfire support: yes
Warranty: 2 years
9. Turbo-Cool 1200 Power Supply
Output: +5V @ 30A,+12V@100A (115A peak),-12V @ 0.8A,+3.3V @ 24A,+5VSB @ 4A
Continuous = 1200W
Peak = 1400W
Crossfire support: Crossfire Certified
10. XIGMATEK HC NRP-HC1201 1200W
http://us.st12.yimg.com/us.st.yimg.com/I/directron_2014_108193411
Output:
+12V3@36A,+12V4@36A,-12V@0.8A,+5VSB@3.5A
Crossfire support: Yes
11. PC Power & Cooling PPCT1200ESA 1200W ATX12V / EPS12V SLI Ready CrossFire Ready
Output:
Crossfire support: CrossFire Certified
Which one do you think looks the best, and which do you think performs better?
Are there models in this list you would not recommend, and why is that?
Message edited by yaoiboimi on 09-10-2008 at 08:04:00 PM
Sponsored Links
Does the power supply sizing calculator at http://www.extreme.outervision.com [...] orlite.jsp advise that you need a 1200W PSU???
------------------------------ There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
The question is your thoughts on looks better and also what you think in just terms of what you think has better performance. :bounce:
Reply to yaoiboimi
- 2 +
"Looks" are the last criterion I have for a PSU. Of those you have listed, I have no doubt that the PC Power and Cooling model is good for every milliamp of its claimed ratings. I'd also trust the Silverstone and OCZ.
Reply to jtt283
- 0 +
Agreed!
Why in the world do you need a 1200watt PSU?
Even sli/crossfire of the most power humgry cards don't need more that the PC P&C silencer 750.
Reply to geofelt
Well I am currently running (2) Radeon 4780 X2 in crossfire,
http://www.tbreak.com/reviews/imageview.php?image=15674
Also powering (12) 12cm case fans, (3) VelcoRaptors will be 4 shortly (running in RAID 5; soon RAID10), also have 7" LCD display from Thermaltake
http://images.tigerdirect.com/skuimages/large/T925-2413-main.jpg
Also running power from the PSU that has a SATA Power connection. I have the Thermaltake Mozart case.
http://blog.miloco.com/images/ThermaltakeMozartTX.jpg
I am currently running a ToughPower 1200W, and wanted your opinions about these PSUs. I am running TT V1 cooler atm, but when Thermaltake comes out with the Freon Cooler, I am going to jump on it, and that operates at 60Watts. I also have a LCD display of both my PSU ussage and fan control, and I am utilizing 78% on idle, and upto 82% on full load of the power supply.
My ddr3 choice I got was Patriot Viper DDR3 1600 (PC3 12800) (2) 2GB
http://www.canadacomputers.com/ProductImages/016972/140.jpg
And cooler for the RAM "OCZ XTC Cooler"
http://www.3dnews.ru/_imgdata/img/2006/11/18/33212.jpg
Message edited by yaoiboimi on 09-10-2008 at 09:25:49 PM
Reply to yaoiboimi
i love my Silverstone 1200watt. I've never had any problems out of it, and it's an 80% unit good for up to 1000watt output.
Reply to reddozen
Jesus that's one hell of a rig. What do you do with it? That's what I'm dying to know!
Reply to rodney_ws
- 0 +
You are using 78% of the PSU's capacity on idle? That's scary...
Of those listed, I'd pick the Turbo-Cool. Expensive, but worth it for a rig like yours.
Edit: Just curious: what motherboard did you get, and are you using a RAID card or the onboard RAID?
Message edited by aevm on 09-10-2008 at 07:33:06 PM
Reply to aevm
ASUS P5Q3 Deluxe With Wi-fi-N
http://xtreview.com/images/Asus%20p45%20P5Q3-006-b.jpg
Message edited by yaoiboimi on 09-10-2008 at 09:27:39 PM
Reply to yaoiboimi
perhaps you could just get a smaller dedicated one for the gpu's as that would reduce some of the load.
------------------------------ I'm a git, deal with it.
Antec 1200,PC Power & Cooling 750,Gigabyte DS4-x48,Intel Q9550@3.4 W/Xigmatek S1283,8GB OCZ DDR2 800,ATI 4870X2,X-FI>CA 640C amp>Tannoy R300/Senn 595's
Reply to strangestranger
I always vote for the PCPower and cooling PSU.
That's one hell of a load you have on your system, I hope you live in one of the places where the electricity is cheap.
Reply to bobbknight
Toughpower 1200W Power Supply is what I run and it's nearly silent with excellent reviews. It exceeds the efficiency rating according to independent testers. I don't even think many of the others were out when looking.
Reply to bydesign
+1 for PC Power & Cooling. Damn... 78% idle?
------------------------------ http://farm3.static.flickr.com/2617/3815217176_0a5be7955d_o.gif
http://farm4.static.flickr.com/3553/3818083596_1a772f7162_o.gif
Reply to Shadow703793
When Thermaltake comes out with the 2000W PSU I am probably going to consider buying it. I still have thoughts 1200W of power even at 87% efficiency will not be enough power for future upgrades that I have in plan. I don't care if my electricity bill goes up more, not that important to me.
http://www.legitreviews.com/images/reviews/520/thermaltake_2000.jpg
When I do go for freon I am thinking I will also put these on my 2 Radeon 4870 X2 for cooling.
http://www.pureoverclock.com//images/news/coolit_hd4870x2_cooler.jpg
http://www.pureoverclock.com//story.php?id=2729
Message edited by yaoiboimi on 09-11-2008 at 07:20:57 AM
Reply to yaoiboimi
- 0 +
I say PC P&C
Reply to cjl
There are 1163 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
