Probably not. I'd invest in a better power supply. Seasonic, corsair, antec, even fortron would probably work better. Don't buy some lightweight no name unit. I had one burn out in 4 days. If you don't want to change power supplies, check newegg's open box section. They have some low end 3650 or 2600xt's that might run without a new ps.
I'll disagree with o1die. Delta make pretty good power supplies, in fact Antec changed from Seasonic to Delta for their Earthwatts series. I'm still waiting on more information about the HD4670, but the 9500GT only uses 35w of power. Here's a chart of graphic card power use.
http://forums.atomicmpc.com.au/index.php?showtopic=264 here's a hierarchy chart showing rankings for graphic cards.
http://www.tomshardware.com/review [...] 011-6.html and a handy power supply calculator.
http://extreme.outervision.com/psucalculatorlite.jsp I'd have no problem with running a 9500GT on my personal system with that power supply.
*edited a doofus mistake*
Message edited by dirtmountain on 09-11-2008 at 08:57:14 AM
