Tom's Hardware > Forum > Overclocking > General Discussions > Help with AMD overclocking (955 BE)
Forum Overclocking : General Discussions - Help with AMD overclocking (955 BE)
Now that my new cooler has finally been installed (corsair h50) i want to try to overclock my 955 BE. Here are my full system specs:
AMD Phenom II x4 955 BE
OCZ gold amd DDR3 1600 ram currently at 1333 with 1:3.3:3 ratio or something close to that (8 gigs-4sticks)
MSI 790FX GD70 Mobo
Nvidia Geforce GTX 295
Corsair 750tx 750W psu, single rail
WD Caviar Black 1 tb
Creative Sound Blaster X-fi extreme gamer
First i want to mention a problem i had before: When i went into bios to change the multiplier from 16-16.5 (thats only 3.2ghz to 3.3!!) i couldnt boot the system, my monitor just said DVI no signal. So i had to remove 3 of my ram sticks in order to see the screen and boot up again. Why would the system do that? And how can i overclock without this happening?
PS: my target OC is 3.8 ghz
Message edited by yannifb on 08-05-2009 at 11:26:45 PM
Sponsored Links
Those timings 1:3.3:3 are wrong. They should be:
8-8-8-24
Voltage should be 1.65v.
You may have to supply some extra voltage to the CPU to overclock.
------------------------------ Google is your friend and Bob's your uncle
Reply to evongugg
Run CPU-Z and check the SPD tab for the timings according to the speed you want to run your memory at.
Message edited by evongugg on 08-05-2009 at 03:02:52 PM
Reply to evongugg
You may have to increase your memory voltage, increase Northbridge voltage one notch and relax timings with that amount of memory.
Reply to evongugg
the 1:3.3:3 was not the timings, sorry. That was the ratio it says in BIOS when i set the ram to 1333. The timings according to cpu z are 8, 9, 9, 20, 33. And the FSB to DRAM ratio is 3:10
Reply to yannifb
bump, i need to know if im good to oc b/c i dont want to wait to long
Reply to yannifb
safe yourself alot of trouble and do this
leave the multiplier for now
raise the fsb from 200x16 to 220x16
------------------------------ Asus Striker II Extreme (Ultra 790i Chipset) | Q6600 @ 3.1GHZ | 4GB DDR3-1425 | GTX 295 | 1TB WDB Hard Drive, +1.2TB | 1000 Watt Power Supply | Corsair H50 CPU Liquid Cooling | Antec 1200 Gamer Case | Logitech G15 | Razer Mamba | P20348 3DMarkVantage
Reply to TerminatorXT
There are 1290 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
