okay i just bought my 4870 from best buy.
when i installed it i was not pleased :non:
it got poor frame rates!, here are my specs...
amd athlon 64x2 4600 running at 2.66ghz
windows vista 32bit
2gb ddr2
apevia iceberg 680 watt power supply
visiontek 4870.
when i had my 8800gt 512mb installed. i would get around 25fps average.
now with the 4870 with the latest drivers, i get less than 19 frames per sec!!
please help me out!
Sponsored Links
that makes no sense. ati's 4800 series destroys nvidia's 8000 series.
what motherboard do you have? maybe there could be an issue there...?
Reply to hhahaahyea
did u do clean install for drivers? n removed the old ones fully?
------------------------------ Q6600 @ 3Ghz | zalman 9700NT cooler | gigabyte P35-DS3L | Kingstone DDR2 667 2GB x 2 | HIS 4850HD with Accelero S1 Rev.2 | enermax Liberty 500w | Coolermaster C5 case |
Reply to night_wolf_in
- 0 +
I'm also betting the 4870 is having an identity crisis with leftover nvidia drivers. Drivers can be hard to fully get rid of, do some searches on the subject to make sure you get them all!
Reply to jevon
I think you have apoor power supply. Certified are recommended.
ATI Radeon HD 4870 System Requirements
500 Watt or greater power supply with two 75W 6-pin PCI Express® power connectors recommended (600 Watt and four 6-pin connectors for ATI CrossFireX™ technology in dual mode)
Certified power supplies are recommended. Refer to http://ati.amd.com/certifiedPSU for a list of Certified products.
http://ati.amd.com/products/radeon [...] ments.html
------------------------------ Google is your friend and Bob's your uncle
Reply to evongugg
okay ima try to delete all nvidia files on my hardrive.
exept the motherboard one i guess.
Reply to dannyman
Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > 4870 problem
There are 1347 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
