Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Dual 9600GT setup, DVI problem
Forum Graphic & Displays : Graphics Cards - Dual 9600GT setup, DVI problem
Hi There,
Recently I did get myself a new system:
- EVGA 780i Mobo
- 2 EVGA 9600GT videoboards (not in SLI mode)
- 2 Samsung 2253BW LCD monitors
- Intel QuadCore 9450
- 4 Gig of RAM
- Windows Vista Enterprise x64
- 700 W PS
The problem is that I can't have my 2 monitors hook up through the DVI ports. The best I can achieve is 1 DVI connection and 1 Analog connection. I have tried all possible combinations on the 4 DVI ports this system has to offer. Do you have any ideas. How to overcome this issue and have each of my monitors hooked up to a separate videoboard through DVI?
Regards,
Rob
Sponsored Links
Perhaps I need to add that I am currently using the OEM drivers, might switching to the standard NVIDIA drivers be an outcome? As I think they're using the same codebase...
Reply to robbie1969
I think the new, yet to be released drivers will do the trick. Search for "Big Bang II" on the forums or some tech newspages and you will see.
Reply to Slobogob
There are 667 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
