i'm about to convert to sli ( 8800gtx superclocked x2) I was looking at some 850 ish watt psu's on newegg and there are some deals. but i see several of that range with three sets (pairs) of chords for my gpus but the psu says sli certified upto 2 gtx's or ultras. could i run 3 cardds eventually? or does it mean you could run three cards, just not three gtx or ultras? i wish the descriptions/specs were more specific. i'll probably get a 780i ftw soon and i only have two gpu right now but in a few months i could always throw another in. my point is, if i wanted to , could i? or do i need a more expensive supply. I know 850 watt is plenty for two cards. I think its possible it could handle three but i know you should always have more than you need for stability sake. and why advertise their certification or support which is less than the chords supplied with it? wierd .. anyways maybe someone can clear that up for me. and then there is certified vs. supported . i assume certified is better, but what is the technicality that separates the two. nvidia vouches or something?
quite the brain drool i left there for you,
thanks in advance , i could really use some quality insight
heres what i have and could potentially upgrade too (too cheap not to)
currently have:
q6600
ab9pro
8g corsair ddr2 800 (6400)
two harddrives
two optical drives
around 5 or 6 fans half 90/ half 120
definate upgrades in the works:
780i/ftw
additional 8800gtx superclocked
psu
oc my cpu
possible upgrades within a few months:
3rd gpu whether it be a professional card or third gtx for tri sli
currently have:
q6600
ab9pro
two harddrives
two optical drives
780i/ftw
psu
oc my cpu
