Apologies for piggybacking, but I have an Asus hd4870 Dark Knight coming. I planned on using an Antec True Power 550w circa 2004 (no six pins). Will this suffice with the correct adapters or should I update my psu?
um. it should work. as long as u have molex to 6pin pci adapters. but yes, a upgrade would be worth it. maybe a corsair psu no larger than 750 is needed
------------------------------Core I7 920 @ 3.66ghz | Xfx 4870 1gb Tri-Fire | DFI Lanparty x58 UT | G.Skill Trident 3x2gb @1834mhz | Asus Xonar Dx | Coolermaster Ultimate 1100w | Coolermaster Storm Sniper case | BenQ E2400HD 24inch 1920x1080 | Thermalright TRUE Push/Pull Fan |
Reply to stevensl2
12v is 24amps Model is True550. I remember it was a pretty strong PSU back in my OC days. It has 7 pin atx plugs and wont power much else other than one sata hard drive and optical on a 780g mobo with the Phenom 9950.
