Use DDR2-800 with a P35 chipset mobo. You can overclock it, but native 1066 has compatibility issues with that chipset.
Although bigger than you need, the PSU is a nice one and offers a comfortable margin.
If you think you will overclock, it will be easier to get a CPU cooler now and install it before mounting your mobo.
If it will fit your budget, get the e8400.
------------------------------There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
