Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Connecting the front panel wires to the motherboard..
Since I'll be building my first PC in a few days I decided to take apart and put back togather my old PC. I did all of this just fine, but am having problems trying to figure out how to properly connect these three wires. They are labeled on the black tip: Power SN, Power LCD, and HD LCD. there are about 8 pins in a row, 6 pins clustered together and the other two separated by two blank spots for pins, and a little ways above this row of pins are 2 more pins. The first time I connected all 3 cables on the row and it wouldn't start, so I connected the power LCD cable in the 2 pins that are slightly above the row of pins and it started but would not let me pass the screen asking me if I wanted to start in safe mode or not. When I select safe mode for example it shows it loading 6 files from the WINDOWS folder and just freezes.
Sponsored Links
New MB will should have a detaled diagram illustrating proper front panel connections. Attach the front panel leads to the MB header before you bolt down the MB down into the case.
Reply to badge
Thanks a lot. The PC is an emachines T1150 and I haven't found any manuals online detailing the motherboard.
Reply to legato89
There are 653 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
