It looked really good aside from the video card which I plan on getting 2x Radeon HD 4850.
Since I will be doing crossfire do I need a different power supply? If so which one is good. Also do I need to order anything additional to be able to do the crossfire?
Aside from the changes I have referenced any others you would make?
The WD 500GB is slow. Get WD 640GB instead (WD6400AAKS).
$110 for that FSP 600W is too much. 750TX is $110 too and it's a much more suitable PSU for HD 4850CF.
I don't buy Sony products of any type, size or color. In particular the Optiarc is not a very good burner, according to what I've read. Get a SH-S203B or SH-S203N.
The NZXT Tempest is a fantastic choice for HD 4850CF. If you want something without lights get a RC-690.
What you need for HD 4850 CF Crossfire: powerful PSU, case with really good cooling, two HD 4850 cards, motherboard with Crossfire support - preferably X48 for max speed. Yeah, you got it all.
Q9450 330$
gigabyte x48 ds4 225$
2x 4850 around 350$
corsair 650tx 90$
corsair xms2 dhx 2x2gb ddr800 80$
xigmatek cooler and retention bracket around 40$
For the case let's say Tempest like in the TH build 110$
artic silver 5 thermal grease 6$
dvd writer let's say 30$
Western Digital Caviar SE16 WD6400AAKS 640GB 90$
Q9450 330$
2x 4850 around 350$
corsair 650tx 90$
Total: 1351$ and thats a monster!
That 650 watt power supply is cutting it a little close (and definitely not enough if he is overclocking).
Take the safe route and go with aevm's suggestion of the 750 watt version.
------------------------------Take my love, take my land, take me where I cannot stand.
I don't care, I'm still free you can't take the sky from me.
Reply to njalterio
If you already have XP sitting around, just install XP and wait on Vista. It'll save you a little money in the short run. Otherwise, go Vista Home Premium. Most say that the features on Ultimate aren't worth the extra cost.
That's pretty much what I'd buy for myself these days. Very nice.
Change the Q6600 to OEM, not retail. That saves you $20 and apparently you get a better CPU too (with a lower VID, i.e. overclocks better).
http://www.newegg.com/Product/Prod [...] 6819115018 You lose the stock cooler this way, but it's garbage anyway compared to the Xigmatek and you can only use one cooler.
The Burner and HDD come OEM i.e. without SATA cables, but the motherboard comes with those cables. No worries there.
I'm assuming the Tempest comes with the screws you need for a few HDD/burner drives. If not, you may have to go shopping for screws indeed. Wait and see.
Good point. Since the budget is up to $1500, there's room to upgrade the 4850 to 4870. This is a gaming PC, and the GPU is the most important part, so yeah, good idea.
Aevm - $1540 might be workable- depends on the shipping cost - but if it is that much better for the video cards - probably worth it!
One question about doing crossfire with the video cards. I have never done this so new to me. How do the video cards connect and which one do I put the monitor on?
Also for the CPU OEM - I changed that - the cooler then is in place of the heatsink that comes w/ the retail of the processor?
Do I need some sort of extra cable to connect them?
OK I will re-work this and then re-post.
Message edited by TheDJ08 on 07-18-2008 at 08:39:51 PM
Yes, the Xigmatek is installed on top of the CPU, just like the stock cooler. If you buy retail you have to throw away the stock cooler before you can install a better one.
Cables: Here's a 245BW monitor, just as an example. As you can see, it has a single DVI port. It also comes with a single DVI cable anyway. Use the DVI cable to connect one card to the monitor. If that doesn't do it try the other. Sorry, I have no idea which one, go ahead and experiment...
I built the computer yesterday, no big problems, it booted up got to the Bios and it looks great so far. I appreciate all the help on the forum, a lot of good advice.
One question on the fans. The CPU fan is detected and shows me the temp, but none of the other fans do. If possible I would like to monitor them. The fans have the 4 pin molex connector, which I used, but also a 3 pin connector that can go to the mobo. Should I connect the 3 pin?
Also - what should be the max temp the CPU gets before setting off an alert?
Thanks again.
Message edited by TheDJ08 on 07-28-2008 at 06:03:27 PM
