Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > SpeedFan and Nvidia System Monitor showing different temps
Forum Homebuilt Systems : General Homebuilt - SpeedFan and Nvidia System Monitor showing different temps
Sponsored Links
Check the advanced settings in your bios. There should be a place that shows you your hardware temps. Monitor it for an hour or so and see what it averages with no load. Then compare it to the data you get from SpeedFan and NvSM. Which ever is closer is probably right. I found the same problem and the NvSM was closer.
AWS 32°
Reply to devlynsyde77
There are 1315 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
