Tom's Hardware > Forum > CPU & Components > Sound Cards > Using a pc with a home theater system
Forum CPU & Components : Sound Cards - Using a pc with a home theater system
I was wondering if it's possible to hook up my pc to a home theater system to use those speakers instead my regular pc speakers. i ordered a creative x-fi extreme audio pci-express, which has an optical out. the home theater system has an optical in. obviously i would think i could just connect the two together. does anyone have any experience with a setup like this? how well does it work?
------------------------------ ECS A780GM-A, Phenom II x3 710, 4GB Corsair @800Mhz, HIS Radeon 4850, Seagate 7200.11 500GB, Auzentech X-Plosion 7.1 Cinema, LiteOn DL-DVD w/Lightscribe, ASUS TA-863, OCZ StealthXStream 500W, Samsung Syncmaster T240, Windows 7 Ultimate x64
Sponsored Links
Use a headphone jack to A/V Cable.
Reply to hitch_united
- 0 +
The optical is the way to go, and it should work fine. I have my comp hooked up to a Denon 2808 with optical right now.
Message edited by cjl on 09-16-2008 at 05:38:47 AM
Reply to cjl
- 0 +
does anyone know if it's true that i can only get 2.1 through the optical? i've read that you can only get true 5.1 surround if you're watching a movie.
Reply to Nik_I
- 0 +
You can only get 5 or 7 channel surround through the optical with something like a dolby digital or dts encoded source. The newer X-fis (the Titanium series), as well as several other cards, are capable of dolby digital live encoding, where they take a 5 channel source and encode it into a dolby digital signal with the complete surround. If your card cannot do that however, the best you will get from non-encoded sources is 2 channel PCM (although it will be quite high quality).
Message edited by cjl on 09-16-2008 at 04:38:55 PM
Reply to cjl
- 0 +
thanks for the help guys.
Reply to Nik_I
There are 971 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
