OK, I have trawled interent forums to attempt to discover the issue my PC has faced. The initial spec was taken from the Gaming PC component suggested in Custom PC mag and modified to:
Vista Home Premium
Intel Core 2 Quad Q6600
Asus P5K Premium/Wifi-AP
4 x 1GB OCZ PC2-8500 Reaper HPC Edition
Tuniq Tower 120
BFG NVIDIA GeForce 8800 GTS OC 512MB PCIe 2.0
Be Quiet! Dark Power Pro 650W
Samsung SpinPoint - 250GB
Samsung SpinPoint - 750GB
Antec P182
Creative Sound Blaster X-Fi extreme Gamer
The system worked fine for over 3 months, including an overclock from 2.4Ghz to 3.1Ghz
Then I attempt to switch the PC on and no boot, classic dark screen, fans spin, lights up on motherboard etc. Nothing else
so I follow onlone instructions to strip system down and try again. This seems to work and I build system. Then it happens again, I phone engineer, he suggests motherboard, as I had run diagnostics on everything else. Ok new motherboard it is with an RMA on original ( I have work to be completed as I make films and cannot wait for weeks/months for replacement, buisiness will pay, sort out later) I take original board out to locate serial code and replace, trying it out once more. To my surprise it boots. The next day it fails
New board. Hoorah. Install new board, nothing, same problems.
Take to engineer, boots fine, evertytime.
take home, boots for a while, then not. Buy stick of ram to check system, no joy. hmmmmm
PC stays with engineer for a few days. It boots everytime for him. No problem with any other components
Look on forums, similar problem with P5K once bios is changed, suggestion to always boot from cold, power leads out etc. This works a few times. then no boot
Ok, check forums (this is all done on my trusty laptop btw) and discover thread with same problem, with pretty much same set up (Custom PC mag spec) User finds solution by buying a different Motherboard after 2 P5Ks. Asus Rampage is ordered, along with New Vista OEM (bloody licence con).
Take to engineers workshop, it boots and I remove all the data I need to save prior to reinstall
So today I put board in and same problem no boot.
WTF....
... can it be my domestic power supply? I have no major power lines nearby and have tried in other sockets around teh house. Will be taking back to engineers to set up new OS etc and then no idea what to do.
I would suspect something wrong with a component, but it boots fine at the engineers.
Anyone?
Vista Home Premium
Tuniq Tower 120
Antec P182
WTF....
Anyone?
