Tom's Hardware > Forum > Homebuilt Systems > New System Build > HELP! Question about memory placement
Forum Homebuilt Systems : New System Build - HELP! Question about memory placement
So I'm using an Asus P5Q Pro motherboard, and its manual is not really clear on where to place the memory.
To those not familiar with the board, there are two channels, channel A and channel B. For each channel, there are two sockets, DIMM_A1, DIMM_A2 for channel A, and DIMM_B1, and DIMM_B2 for channel B.
I'm trying to install the G.Skill 2x2GB PC2-1066 RAM, and the QVL that came with the mobo manual didn't have it. I found this online: http://kj.gnt.hu/details/mb_spec/u [...] xe_qvl.pdf
for a similar board, and it told me that it was type A only.
type A: supports one module inserted into either slot as single-channel memory configuration.
Now my questions:
1) Is single-stick operation possible? (i.e. only 2GB at first until I can get a POST)
2) When I use both sticks, would i do DIMM_A1 and DIMM_A2, or would I do DIMM_A1 and DIMM_B1?
Thanks!
Sponsored Links
A1 and A2
most mobos have the channels colour-coded, just go with that
Message edited by jonyb222 on 07-18-2008 at 07:08:51 PM
------------------------------ It is a very newb question, which is why I ask it.
Reply to jonyb222
- 0 +
I'm not really quite sure what you mean, but it is possible to have one or two sticks in when you first try it.
And you can put the ram wherever you want, but for it to run in dual channel, there has to be one space between them, which I believe would be either DIMM_A1 and DIMM_B1 or DIMM_A2 and DIMM_B2
Reply to yadge
There are 1239 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
