Tom's Hardware > Forum > Homebuilt Systems > New System Build > New System Build, looking for advise before I buy
Forum Homebuilt Systems : New System Build - New System Build, looking for advise before I buy
Below is what I have come up with, I am reusing my CD/DVD drives and my Audigy 2 Sound Card. Down the road I will probably get another vid card for crossfire and look into liquid cooling. Anything look out of whack or NonCom?
Antec Nine Hundred Black Steel ATX Mid Tower Computer Case
Model #:Nine Hundred Item #:N82E16811129021 $119.99
Update MSI K9A2 Platinum AM2+/AM2 AMD 790FX ATX AMD Motherboard
Model #:K9A2 Platinum Item #:N82E16813130136 $149.99
Update HIS Hightech H485F512P Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card
Model #:H485F512P Item #:N82E16814161235 $184.99
Update Antec TPQ-850 850W ATX12V / EPS12V Power Supply
Model #:TPQ-850 Item #:N82E16817371009 $139.99
Update AMD Phenom 9850 BLACK EDITION 2.5GHz Socket AM2+ 125W Quad-Core Processor Model HD985ZXAGHBOX
Model #:HD985ZXAGHBOX Item #:N82E16819103249 $205.00
Update CORSAIR DOMINATOR 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model TWIN2X4096-8500C5DF
Model #:TWIN2X4096-8500C5DF Item #:N82E16820145197 $149.00
Update Seagate Barracuda 7200.10 ST380815AS 80GB 7200 RPM SATA 3.0Gb/s Hard Drive
Model #:ST380815AS Item #:N82E16822148231 $39.99
Update Open Box: Seagate Barracuda 7200.11 ST3750330AS 750GB 7200 RPM SATA 3.0Gb/s Hard Drive
Model #:ST3750330AS Item #:N82E16822148298R $79.99
Update Arctic Silver 5 Thermal Compound - OEM
Model #:ARCTIC SILVER 5 Item #:N82E16835100007 $5.99
Update Tuniq Tower 120 Universal CPU Cooler 120mm Cooling Fan and Fan Controler/Heatsink - Retail
Model #:Tower 120 Item #:N82E16835154001 $49.99
Sponsored Links
Why do you insist on going with an AMD?
Reply to bpogdowz
- 0 +
NEEEEED SOME HELP!!!!
I am a newbie when it comes to building systems, this is my second build. I put together a system for my in-laws on newegg.com
Motherboard [http://www.newegg.com/Product/Product.aspx?Item=N82E16813128072],
CPU [http://www.newegg.com/Product/Product.aspx?Item=N82E16819115037],
RAM [http://www.newegg.com/Product/Product.aspx?Item=N82E16820145184],
HDD[http://www.newegg.com/Product/Product.aspx?Item=N82E16822136073]
a 500W Antec PSU and CD/DVD drive.
This is the problem I am having... First, I hate the CPU fans that come from Intel and AMD. They are the biggest pain in the rear end EVER! I still dont think I have got the thing secure on there but that is the least of my worries... Anyway, I got all the hardware placed into the case and connected together, hit the power button with OEM version of Windows XP SP3, everything started out great.. I got to the "detecting your systems config" screen and out of nowhere, I got the blue screen of death. Turned the machine off checked all of my connections and now it stops at the boot screen on "verifying DMI pool data" after about two min of sitting on that screen the system shuts down. I dont know! I have no idea what to think at this point. Also, my USB connections on the back didnt recognize my USB mouse/keyboard (4 USB's on rear panel, none work) The only 2 that work are on the front of the case... I figured this out before the blue screen of death. Please help, I really dont know what to do here. How do I test this hardware to find out if it is bad without buying new parts and replacing all of them.... TIA!!
MkLovin
Reply to MkLovin
The Antec 900 is a good case, but it is kinda expensive, so try looking at the Xion II for a cheaper case.
The processor u are looking at right now is overkill! 4 PCI-e slots?!?!?! ur getting 1 4850. u should be spending ur money on a better QUALITY motherboard rather than paying money for 4 PCI-e slots of which u are only gonna use one. If u really want ATI graphics then thats fine, but atleast give yourself an intel motherboard, so u will atlest have a good, running machine. Try getting the intel DX38BT motherboard. Its really fast and itll support ur 4850.
Ill try to recommend a processor to you that is close to what u are paying for the 9850 black edition, so i'd go with the core 2 Quad Q6600(2.4ghz), which can be overclocked to like 3.2 GHZ and its $199. Or pay alittle more and get a Core 2 Quad Q6700(2.66 ghz) which is $260. Either way, u should really stick with this intel mobo and this intel processor. Trust me.
Even tho u have intel mobo and an intel processor, u can still put ur 4850 on it and maybe even do crossfire with them later.
Your power supply looks fine, but for a little more money u can get the Ultra X3 PSU which is fully modular. But what u have now is fine
The DX38BT Motherboard uses DDR3, and that is what the entire world is gonna be using in the next couple of years, so if u want to build a future proof computer, stick with DDR3. I got 2 gigs OCZ 1333 DDR3 memory for $110. 2 GIGS should be more than enough because its DDR3
I dont understand why ur gonna put an 80 GB hardrive in RAID with a 750 GB hard drive. Just get two 500 GB drives if u really want a lot of memory. But honestly i hold all of the movies and pictures and songs for my family, and it all fits fine on my 250 GB HDD. even if i did run out of space, later i could buy another Hard drive and put it in RAID, or i could just get and External drive.
As for cooling, try the Zerotherm Nirvana NV120. It comes with the thermal paste, and it keeps the processor VERY cool. its kinda big tho so make sure u got alotta space.
ALL of these items can be found at tigerdirect.
Reply to falconzfan007
just look for old post
Reply to th_username
You should start your own thread if you want help rather than hijacking anothers.
Reply to rockyjohn
- 0 +
Since that was my first post on this site, I suppose you expect me know how this forum site works? Thanks for your non-informative post. Have a good one!!
Reply to MkLovin
His post was quite informative, you didn't know the rules of the forum and he just informed you of them, no need to be mean about it. Create your own topic so that others can help you more easily and you can receive informative posts. Most forums work the same way, and don't like it when you put your own problems into other people's threads.
To the original poster: I disagree, I'd rather have 4 gigs of ddr2 than 2 of ddr3, maybe if you really needed to overclock you could use the ddr3. Also, the q6600 is great, but if you use the comp for mostly gaming, the e8400 can be overclocked very well and would offer better performance for games. For the power supply, everyone seems to recommend the Corsair 750W PSU if you're OCing and doing crossfire. There are other good ones, but that one on Newegg is one helluva deal.
Message edited by cixelsyD87 on 07-20-2008 at 05:32:38 AM
Reply to cixelsyD87
- 0 +
I went with AMD because I always had good luck and have been very happy and always felt they were more bang for the buck, its been several years since I poked around so I will check out the Intel sinc eso many think its a better choice now. I was not setting up a RAID but just having one small hard drive for the operating system and the other drive for programs, I have another 500 gig in use now for my data.
Reply to EonDel
There are 1159 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
