SSD - The Performance Upgrade of the Future
I have a GIGABYTE GA-965P-DS3 MB and a Intel core duo 6600 cpu. I am not good enough to try to overclock without some help. So if anyone can help, it would be appreciated
For a start: HOWTO: Overclock C2Q (Quads) and C2D (Duals) - Guide v1.6.1 http://www.tomshardware.com/forum/ [...] uals-guide Core 2 Quad and Duo Temperature Guide http://www.tomshardware.com/forum/ [...] ture-guide And here's a guide to a later model of Gigabyte motherboard (BOS should be similar): http://www.tomshardware.co.uk/foru [...] dated-2008
Thanks. Got it running at 3.0 for now but it resets back to 2.4 after sometime.
^ Thats because of SpeedStep or C1E, disable it and it should run at 3GHz all the time
ok, I will look into it
