I know the creative is more expensive, but i wanted to know if its much better than the m-audio and if its worth the money.
or in other words, if the z5500 will use the options that the Creative one gives.
btw you can suggest other sound cards.
using the z5500 for games, HD, and music (in that order).
thanks!
just get a basic creative, i would avoid the asus as i have heard that it ain't that great tbh since it relies on emulation of creative's eax in older games and it doesn't do too good a job of it at times.
it doesn't really matter which speakers you have.
------------------------------I'm a git, deal with it.
Grr all these people buying soundcards for their z5500s, there really is minimal point unless you MUST have EAX. The z5500s really aren't good enough to warrant using a decent soundcard.
