Tom's Hardware > Forum > Homebuilt Systems > New System Build > New gaming rig advice on parts i ave chosen
K i will be OCing this quite a bit hopefully 2 about 3.2ghz and the gpu, any advice 2 change parts but i am on a strick budget so any part advice can u pick 1's around the price of the 1's i chose unless the extra money is really worth it.
CPU: Q6600 (GO stepping)
Mobo: P5Q or P45 Neo or P45 Neo3
Case: Antec 900
HD: Samsung Spinpoint F1 750Gb
Ram: Sum DDR2 PC2-6400 800Mhz CL4 ram, maybe sum OCZ REAPER X or Corsair XMS2 DHX, 4GB as 2x2GB
GPU: HD4780
CPU cooler: Xigmatek HDT S1283
PSU: Hiper HPU-4M630 630w or Corsair 650W TX
OS: Vista premium 64Bit
Im pretty sure them PSU's will be enough 2 power this even OC'd
Is CL4 ram faster than CL5 ram and wil it be better for OCing
I mainly need help on the mobo, ive chosen a P45 board with only 1 PCI x16 slot as i wont be using crossfire, but wil a P35 board be just as good and cheaper if so can u recommend 1 that is very good for OCing but around £80 or $150
Thx for any help, i will be buying all the parts in about 2 weeks
Message edited by fallen2004 on 07-20-2008 at 03:01:14 PM
Sponsored Links
P5Q PRO
REAPER
HIPER 630W
Reply to akhilles
Thx
Y get the PRO over the basic 1, i dont need the 2nd graphics slot and i dont see any other reasons 2 buy the pro which is more expensive
Reply to fallen2004
because you want to OC. The BIOS is not the same between the boards. the pro or the -E are better choices.
- and no to the reapers. They are having issues on the ASUS P5Qs. Check Corsairs site for compatibility and go that way.
Reply to Proximon
There are 1088 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
