I'm hoping someone could answer a question about Power supply lifespan. If you run a well made power supply rated at a much higher wattage than your actual power needs does it significantly extend the lifespan of the PSU before it's performance starts to deteriorate. For instance an Antec TruePower Quattro TPQ-1000 1000W PSU in a system running a single 4850, an intel e8500, an hd, 4g ddr2, and 2 optical drives(just an example no need for specifics for that particular Configuration).
My interest in this would be in terms of upgrading to crossfire/sli later adding more ram and possibly eventually overclocking.
Also, what effect if any would upgrading with aftermarket or water cooling have on the lifespan of components that aren't overclocked.
I'm thinking about ordering a new system in or over the next couple months with an eye towards long term stability and upgradeability.
I've read the recommended load on the ps shouldn't exceed 60% during normal usage. You'll have to list your specs to determine load requirements. You may extend the life of some components with a good ps, but most systems don't require 1000 watts. To extend the life of my components, I prefer some simple fan upgrades, and a yearly cleaning with a good canned air product to get the dust and crud off the fans. I use "perfect duster" a product sold at fry's electronics. You can also do what I sometimes do: buy a spare motherboard. Motherboards are only produced for a short time; I'm about ready to stop upgrading for awhile, so a spare board would be a good investment. Checkout newegg open box boards if you plan on keeping your system for 5 years. And if you decide not to use it, you can get most of your money back by selling them in the hardware forums.
Message edited by o1die on 09-19-2008 at 08:24:18 PM
