I'm thinking of getting 2x 4870x2 for quad crossfire as an upgrade from an aging 8800gts. What kind of power would be needed? Would a 850w psu be enough? All specs in sig.
Also, would it make a difference if I combine the 4 small 12v rails into a single large rail? There is a switch on the back of my current psu that does this.
850w seems like it would be enough. wats the rest of ur system?
yes combine the rails i heard its better when a psu has 1 rail. how many amps does it have?
------------------------------intel core 2 quad q6600 @3.2ghz msi p6n diamond (X-FI Extreme sound) 6gig of OCZ+CoRSAIR oc 900mhz Nvidia gtx 260 sli @ 730/1465/1250
Lite-On Blue-ray Western Digital 7200rpm 500gb Antec 500 Earthwatt Window vista 64-bit
Reply to invisik
each 4870 x2 will require 250 watts. So that's 500 watts just for graphics cards. an overclocked q6600 takes about 184 watts. that leaves 166 watts for other things. You also have to take into account aging of the psu. I would say it would be cutting it too close.
Message edited by fly2hip8 on 08-12-2008 at 02:44:59 AM
------------------------------Cooler Master Stacker 830 Cooler Master Power Pro 1000w
Gigabyte GA-X38-DQ6 Intel X6800
Sapphire 4870 X2 Swiftech H20-220 APEX 220
1 WD 250 GB HD 2 WD 1 Terabyte HDs
Reply to fly2hip8
How about this: get one HD 4870x2, use it for a while. In the meantime AMD will make sure HD 4870X2+HD 4870 is supported by drivers. When it is, add a HD 4870. A third GPU adds value in some games (a lot in CoD, less in Crysis, etc.). A fourth GPU doesn't add much, AFAIK. With only 3 GPUs I think your PSU will be enough.
Core 2 Duo E8400 Processor @ 3.0 GHz (FSB 1333), the ASUS P5E3 Deluxe mainboard, stock cooling on the CPU, DVD-rom and a WD Raptor drive
Videocard
System Under FULL load
Radeon HD 4850 269 Watt
Radeon HD 4870 334 Watt
Radeon HD 4850 Crossfire (2) 421 Watt
Radeon HD 4870 X2 (R700) 437 Watt
Radeon HD 4870 Crossfire (2) 480 Watt
Radeon HD 4870 X2 (R700) Crossfire 740 Watt
If you can afford 2 4870x2's, then you can afford a new power supply. Methinks you're not actually going to buy this... you're just curious. Pics or it didn't happen!!!
