which power supply
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - which power supply
hi all i am looking to buy a new power supply, but am not sue which one to chose, my spec is
CPU E6600 Intel core2 Duo 2.4GHz
Motherboard ASUS P5B deluxe – wireless
RAM 2GB – 2x1GB MUSHKIN PC2-EM6400 5-5-5-12
VGA NEW Xpert Vision GeForce 8400GS 256MB PCIexpress Graphics Card
PSU NEW PSU Trust 570W Pro
Sound onboard
DVD and CD drives
Storage Hitachi 250GB
i have overclocked the cpu to 2.8 and i am looking to upgrade to a hd 4870 in the near future.
any sujestions and good deals will be helpful
thanks in advance
Sponsored Links
What country are you in?
If it's the US, then these are good deals right now.
PC Power & Cooling S61EPS 610W
CORSAIR CMPSU-750TX 750W
Message edited by Zorg on 09-20-2008 at 08:44:46 PM
Reply to Zorg
570w is still enough with the overclocking, ample headroom too, you don't need to buy a new one.
------------------------------ Q6600@3.6ghz, GA-EX38-DS4 motherboard, 8gb 800mhz ddr2 4-3-3-12, 8800GTS(g92)@780mhz, 1TB + 1.5TB hdds, 850watt psu
Reply to dagger
True, but I don't trust Trust. :lol:
Who are they, do you know?
Reply to Zorg
Brands aside, the power level is more than high enough. No reason to not try it out. Unless defective, it'll work.
Reply to dagger
thanks for the replies but i am in England so the deals dont apply to me
as for the "brand aside comment" i took this approach the first time and now i need to upgrade. I am looking for a reliable psu with good reviews, that i can trust, what brand do you thin i should go for?
Reply to coleman
What site do you order from?
Reply to Zorg
You know, you're not actually changing hardware, just ocing. And it doesn't go anywhere near the limit of the psu. Since your old one worked fine so far, it's a good bet that it's not defective and will continue to work when load is slightly higher.
Reply to dagger
I will order from any uk site
Reply to coleman
Using the eXtreme Power Supply Calculator Lite v2.5 with an OC of 3.2G and Vcore of 1.35, which are both high, I got a recommended PSU size of 453W. All loads were at 100% and the VGA was a 4870. With a capacitor aging of 25%, the number climbs to 566W. So I would go for 600W or better for long term use, and future expansion.
I found a really good choice, but it isn't in stock yet. It is a good PSU and is relatively cheap. You could call them and get an ETA.
Scan Computers UK: TX650W Corsair PSU OEMed from Seasonic
Another good choice, but expensive because of the modular cables.
Tekheads.co.uk HX620 OEMed from Seasonic.
The least expensive and good, but not as good IMO.
ANTEC EA650-GB/Earth Watts Used to be OEMed from Seasonic with a lesser build spec., but now OEMed from Delta. I haven't seen any Delta OEM reviews.
Larger than you need and more expensive, but excellent.
PC Power & Cooling SILENCER 750 QUAD (Black) OEMed from Seasonic.
Message edited by Zorg on 09-21-2008 at 05:09:44 AM
Reply to Zorg
thanks zorg, thant helped me alot, i am liking the corsair, and it is a brand that i trust.
Reply to coleman
Corsair is a good brand. I'm not a fan of the modular cables on the HX, but I think I might be in the minority.
Message edited by Zorg on 09-21-2008 at 06:29:34 PM
Reply to Zorg
modular cables?
do u have any suggestions for psu for overclocking
Message edited by coleman on 09-21-2008 at 06:34:35 PM
Reply to coleman
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > which power supply
There are 1103 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
