I need some help. I just got a new computer and whenever i talk on the mic the sound from my headphones go through it on Ventrilo and all other programs. How do i fix this? I forgot how I did it on my old computer. This is also a xp
Sponsored Links
Are you saying you're hearing your own voice on the headphones when you speak into the microphone?
I don't really understand what you are saying here......
------------------------------ GA-X38-DS4 (BIOS F3)||E8400 C2D (3.6GHz)||2x 1Gb Crucial Ballistix DDR2-800 4-4-4-12||320Gb WD Caviar||2x 750Gb WD Caviar||Cooler Master Real Power Pro 750W||2x HD4870 512Mb(Crossfire)||HT Omega Striker 7.1
Reply to jay_l_a
- 0 +
I don't really understand the question either, so here's my half-bewildered response:
It sounds like you have playback turned on for your mic, so that whenever you speak, it is played back through your speakers. Try entering your sound controlling program / menu / system / the thing that controls your mic gain and feedback. There should be an option there to turn off playback.
Reply to seboj
Switch the default headphone playback device in the control panel.
Reply to gamerk316
- 0 +
thanks its fixed
Reply to vito11
Tom's Hardware > Forum > CPU & Components > Sound Cards > Sound problems
There are 1314 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
