What is the best Small PC Case?
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - What is the best Small PC Case?
Can anyone give me suggestions on a small PC case for a budget build?
I heard that INWIN makes good stuff but I want opinions from other people.
If you know a good budget build non-gaming PC case please post a link to it.
I am interested. With or with out a Power Supply. Does not matter.
Sponsored Links
Something like this delivers good cooling in a small package.
http://www.newegg.com/Product/Prod [...] 6811119088
If you're purely looking for low cost, and don't really need the small size, consider using a normal midtower. Mini cases are actually more expensive overall than mid towers. One is mainstream, the other is not.
http://www.newegg.com/Product/Prod [...] rder=PRICE
------------------------------ Q6600@3.6ghz, GA-EX38-DS4 motherboard, 8gb 800mhz ddr2 4-3-3-12, 8800GTS(g92)@780mhz, 1TB + 1.5TB hdds, 850watt psu
Reply to dagger
In win FTW!!! Special Floral exterior design paired with SWAROVSKI crystals..nuff said. lol seriously it comes in a standard silver color. but overall a nice clean design.
Reply to PsyKhiqZero
- 0 +
Silverstone TJ-08
Antec NSK-3480
Reply to tim851
The GT3 Case is pretty cool. unlike all other small PC cases, it supports full size(ATX) motherboards.... and its pretty cool design as well
http://www.gtrtechcorp.com/ or http://www.gt3pc.com/
Reply to Ha11ster
When you say small pc case, do you mean a micro-atx or small form factor (sff) case? Will you be using a standard atx or a micro-atx motherboard? Are you going to be using a short or a long video card? Are you going to use a stock cpu cooler or a tall tower style cpu heatsink? All of that information makes a difference in case selection.
Reply to JohnnyLucky
- 0 +
InWin? You gotta be kidding me..... For the price of a decent InWin you can get an Antec 300 Or CM 690.....
------------------------------ 550 @ 4.0 Ghz 1.425v
BFG GTX 260 (216)
4GB G.Skill @ 960MHz
Thermaltake TP 850w
Reply to OvrClkr
This topic has been closed by Mousemonkey
------------------------------ [:mousemonkey:1] http://img29.imageshack.us/img29/5041/vr2009champ.jpg
Reply to mousemonkey
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > What is the best Small PC Case?
There are 1120 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
