Side Case Fans
Forum Overclocking : Cooler and Heatsinks - Side Case Fans
I have decided I need 4 new side case fans. I am going to have the bottom two as intake and the top two exhaust. Does anyone have any recommenations? I do want to keep it as quiet as possible.
Sponsored Links
im currently using silenx 120mm fans and they are great. But expensive. My computer is on top of my desk and its very quiet cant here the silenx fans but i have 2 stock ones that came with the case and those make like a humming,buzzing sound, still quiet but ima switch them out for the silenx fans. im actually gonna go pick one up this weekend.
Reply to huntsman
May I suggest you post a link of your case and your setup?
I can't see in my head why 4 side case fans in a square and two in, two out will really help matters much.
Maybe we can help, with more info about your case and setup of what your currently using for a CPU and GPU. Pics would be nice.
It's sooo hard to Tshoot remotely with no info. Look at it from our end. More info the better.
Reply to Conumdrum
Also See which size/diameter of fans fit on the holes of the case.
Reply to shubham1401
also explain more like conumdrum said, because i also dont understand why u would want 4 side fans and have two intake and two exhause why not just do 2 on the side intake, 2 in front intake and 1 rear exhaust and 1 or 2 on top exhaust but u prolly dont need that many fans.
Reply to huntsman
It will kill your airflow to have two fans going in opposite directions on the same side of the case. Air has to move in one direction throughout the case....in from the front and sides, and out the back and top
Reply to belial2k
Yep. All you will be doing is blowing in cool air and immediately sucking it back out without it cooling anything.
Reply to orangegator
Go for Noctua fans...really great performance and you can't hear s%$t
Reply to Travkin
Front to back is better. It sounds like bottom to top may interfere with the PSU airflow.
Reply to Superhal
Tom's Hardware > Forum > Overclocking > Cooler and Heatsinks > Side Case Fans
There are 1012 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
  • 01:00 xpax won the Freshman badge
  • 01:00 Mizoguchi won the Freshman badge
