Tom's Hardware Forums » Homebuilt Systems » New System Build » OS questions anyone help?
Add a reply
 Word :   Username :
Bottom
Author
 Thread : OS questions anyone help?
Profile: stranger
More Information
I have an AMD 9750, GIGABYTE GA-M750SLI-DS4 AM2+/AM2 NVIDIA nForce 750a SLI ATX AMD Motherboard, Radeon 4870 and Western Digital SATA 640 gig hard drive with a SATA DVD RW. I can get the files of my Windows Vista 64 bit to start loading but once it starts to install the computer reboots. Any ideas? This is a fresh install on a brand new hard drive.
Related Pr oduct
Profile: journeyman
More Information
Do you have two sticks of Ram? Try removing one stick and attempt install with one stick only. Let me know what happens.
Message edited by peter_pete r on 07-22-2008 at 05:03:22 PM
Its not a bug. It's an undocumented feature.
Windows Vista 64bit | EVGA 780i SLI Mobo | Intel Core 2 Quad Q9450 Yorkfield @ 3.4 | XFX GTX 260 | (2x2GB) 4GB Corsair XMS DDR2| (3x320)WD Caviar SE16 SATA 3GB/S | ZALMAN CNPS9700 | Antec Neo PS | ANTEC P182SE
Profile: journeyman
More Information
I have only installed Vista a few times so I can't really remember the process.  I know XPs install and after the files are copied over the system reboots then prompts to boot from cd.  You just ignore that and let it boot to the harddrive or you press F12 and select boot from harddrive.  The the install will continue.
Profile: Ancient Poster
More Information
What is your power supply?
Scruze my English!
Profile: journeyman
More Information
This has been covered before in other posts, but try installing from a IDE optical drive instead of a SATA one. Most Nvidia chipsets have issues with SATA optical drives and will blue screen and reboot during OS installs.
If this solves your issue, you will not be able to re-install the SATA drive as your system will still BSOD during bootup of Vista or XP.
Add a reply
Google Ads
Related Content
