Xp problem With WD5000AADS-32MB Cache
Sir,
I have a problem with my new hdd WD5000aads when i am installing xp sp3 so, it will take 45 min. & After installation it didn't run smoothly even simple moving mouse cursor i am updated my BIOS and installing new chipset drivers but nothing happen But when iam installing Windows 7 Beta ver. it installed in 10 min and there is no problem so, pl z sir suggest me?
system info: D945gcl Intel original board , Dual core 3 Ghz 1.50 GB RAM
10 answers Last reply
More about problem wd5000aads 32mb cache
  1. i doubt it is a hard disk problem, maybe a symptom but unlikely a source.
    sir. please describe yr problem a bit more.
    what happen to the mouse cursor?
    make 100% sure u install ALL the right drivers for XP.
    check yr device driver manager.
    sir, everything will be minty cool and sweet. :)
  2. my mouse cursor is freeze for 2 or 3 second and then move & i am installing latest driver from Intel web site and device manager show no problem with my all devices
  3. this problem is only with xp ,windows 7 is perfectly running
  4. my mouse cursor is freeze for 2 or 3 second and then move & i am installing latest driver from Intel web site and device manager show no problem with my all devices & this problem is only with xp ,windows 7 is perfectly running
  5. try another mouse and is it the same?.
    it could be a few things.
    . malware?
    . apps/driver compatibility? but it's a clean setup...
  6. first thing i want to tell u my hdd is totally unallocated space only 30 gb partiton is created so, i am sure there is no malware Secondly,i am sure my mouse is perfect bcoz it is perfectly running with windows 7 on same pc
  7. i can imagine yr frustration :(
    sry but i'm not sure how to give u an exact solution.
    oh wat mouse r u using?
    here's wat i'll do if it's my pc :)
    . if the mouse comes with a driver like Logitech's i'll uninstall that and try.
    . see task manager's processes and running apps.
    . i'll download Microsoft Sysinternals tools to
    .. look at the processes
    .. check autoruns
    http://technet.microsoft.com/en-us/sysinternals/default.aspx
    . switch to older motherboard drivers to check
    . do clean install XP and don't install any drivers and see if that works
    .. with no drivers install, mouse works - it's driver. try install 1-by-1 to c which 1 is the culprit.
    .. if it doesn't work with clean install, it's native in win XP.
    . scream at the sky and the mouse before calmly update my motherboard's BIOS, with a UPS protecting the PC from power failure.
    . i would remove power to dvd-rom, unnecessary usb devices, network adapters, non-XP-boot hard disk during testing.
    . use built-in INTEL VGA during troubleshooting. remove PCI-Express VGA & other cards.
    hope u find the answer sir. :)
  8. Sir But one thing i want to know that in installation it will take 45 min why? & in middle when it want some instruction like setting up of date,computer name then it was also freeze but in my first 160 seagate drive xp was installed in only 15 min. !!!! & I am updated my motherboard bios when i am running my previous hdd about 2 month ago
  9. go exchange a new drive. :)
  10. That drive uses different sectors then the past, 4Kb instead of 512b. Use the WD alignment tool for XP created partitions. Windows 7 creates 4Kb sectors correctly.
Hard Drives Windows XP Storage
