Tom's Hardware > Forum > Motherboards & Memory > MSI-Microstar > (another) MSI p45 platinum problem
Forum Motherboards & Memory : MSI-Microstar - (another) MSI p45 platinum problem
So here's my problem:
I recently wanted to build a computer, and being new decided to take toms advice and made a build similar to their overclocking marathon sub $1000 machine. Specs:
Mobo: MSI P45 platinum
CPU: E8400
Ram: Corsair 2 x 2 G
PSU: Corsair 550 W
HD: Seagate barracuda 500G
optical: old drive from dell (don't remember brand)
Graphics card: 8800 GT 500 MB
The story so far: Being my first time, the setup probably took a little longer than it should of, but as far as i know I managed to get everything into place without breaking. The first boot attempt was very unsuccessful, as I had no image what so ever on the monitor. I tried to shut off and restart, as I could tell by the lights and sounds that components were working, they were just not giving me an image. I know that the graphics card is good, because until just recently it was in a different pc, everything else on the system is new. After a few restarts I decided to push a few buttons to escape out of the bios, and I did manage to get a MSI start up screen. I restarted one more time (my keyboard was working at this time... more on that later) with my windows xp CD in the drive and everything seemed peachy. I had read about the bios problems of this board and so hoped that once windows was installed and a bios update was in place all would be well.... but back to the windows install. All was going well, and I was doing a full format of my new HD, but the partioning was not progressing past 3 % for several hours. After much searching on the internet and no further progress, I decided that my only recourse was to reset (....fatal error on my part?). Since that point I have had no luck with any thing what so ever. i am unable to get any images on my monitor, and the worst part is that my keyboard will not even register at this point. I am at a loss here. Did i make a mistake by purchasing an MSI product as I have read on other similar posts? I have tried the CMOS reset and unplugging the PC with no results. I am new to system building, and must say it is a frustrating first go. I purchased my mobo from newegg, which has a limited return policy on mobo's. I could eat the cost and get another brand, possibly selling an RMA on ebay, but want to see if there is anything I am missing there. Any help greatly appreciated.
Edit: corrected newegg return policy
Message edited by Phosters on 10-22-2008 at 02:36:27 PM
Sponsored Links
list of things to check:
Are all component properly seated in their brackets? (esp. ram)
is the monitor cable properly plugged in?
Are jumpers properly seated on the motherboard?
Have you plugged in everything that needs to be plugged?
If you have multiple sticks of ram, have you tried booting with only a single stick? Then with only the 2nd one? (and while we're at it, is the ram put in the correct socket?)
Try to plug the HDD in another computer and perform the SMART self-tests to determine the health of the HDD
verify that the motherboard isn't grounding on anything (ie. have you used O rings when screwing the mobo on the chassis?)
Try booting with minimal stuff plugged in. Only video card, cpu, hdd and 1 stick of ram. Use a keyboard that isn't USB (sometimes the option isn't on by default so it doesn't get detected).
If you still have problem by then, try to re-assemble the whole system from scratch in the hope that you do not reproduce any mistakes that you could've done the first time around. If nothing works at that point (swapping components as you go along), it is probably the motherboard. Get an RMA going and try again with a new board :P
Good luck!
Reply to antiacid
Thanks for the advice! I actually got a similar reply from a coworker, and it seemed that I had not seated a RAM module fully. So i did get it to boot, moved on to other problems, but long story short after a driver and bios update it is currently working well. :)
Reply to Phosters
There are 485 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
