Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Need certain power cables, help please
Forum Homebuilt Systems : General Homebuilt - Need certain power cables, help please
Hi,
I'm midway through a computer project, and it would help me out a lot if I could find power chords for my monitor and PSU that are much shorter than the normal length. I would prefer less than a foot in length. That's about the only requirement I have: shorter than the usual. I doubt I'd be able to cut and splice the ones I have, as I have no experience in that area.
thanks for your time
Sponsored Links
Cables are long thats the way life is. Just gather the loose cables and put them in one neat pile.
Reply to fugben
go to your local hardware store in the electrical department. you will find male plugs. cut your cord to the length you want, then strip back the casing and attach the wires into the new male plug. Thats the quick and dirty, or...
http://www.cyberguys.com/templates [...] uctID=6512
------------------------------ If you don't know what OS/2 is, you don't understand.
Reply to rockbyter
All you need is a knife and electrical tape. Cut the cords from the center and splice them back together and put the tape around each individual wire. Don't really need a new plug.
Edit: Just checked out that link. I believe that's exactly what you originally asked for, good find.
Message edited by jeb1517 on 07-22-2008 at 10:28:33 PM
Reply to jeb1517
Yep, that's beautiful rockbyter, thank you very much
Reply to Crazymage
There are 1140 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
