Tom's Hardware > Forum > Graphic & Displays > Graphics Cards > Radeon X800 Question and Replacement
Forum Graphic & Displays : Graphics Cards - Radeon X800 Question and Replacement
My PC Specs Are:
Windows XP Home SP2 (Version 2002)
AMD Athlon X2 5000+ (2.61 GHz)
2 Gigs of RAM
400+ Watt Power Supply
Motherboard: Gigabyte GA-M55PLUS-S3G
Monitor: ViewSonic 20G, 1600 x 1280, Composite to VGA, 20" CRT
(The monitor I got for free and it works great; More Info On It At:
http://www.monitorworld.com/Monito [...] ic20g.html
Video Card: PowerColor Radeon X-800, 256-MB, 256-Bit, PCI-E x16
More Info On Graphics Card At:
http://www.neoseeker.com/Articles/ [...] abytex800/
I'd like to replace the video card with something better. My next video card must be at least 256-Bit and have a VGA port. My monitor seems to have problems with VGA to DVI Adapters. I've tried and get no picture. I've tried researching multiple video cards and come up short. If anyone has any ideas that would be better and faster than what I already have, please feel free to share (Web Addresses to the locations of the cards suggested are Welcome).
Note: I like playing a lot of FPS Games. I'm looking for a Graphics Card for Gaming and Watching Movies on my PC.
Thanks for taking the time to help
Jacob
Sponsored Links
Agreed /\ :) It will play anything you want.
Reply to yay
Good suggestions. Or you can go for a 4850.
------------------------------ Rock journalism is people who can't write interviewing people who can't talk for people who can't read - Frank Zappa
Reply to radnor
The 4850 doesn't have a VGA port. So I would also go with either the 3850 or the 9600gso, both would probably be a good upgrade for you.
Reply to yadge
+1 for 4850 best choice at this moment.
Reply to pulasky
There are DVI-VGA adapters. Graphic Cards usually come with one. If they don't, you can get one dirty cheap.
Message quoted 1 times
Message edited by radnor on 08-14-2008 at 12:18:46 PM
Reply to radnor
Sometimes reading the original post helps. :D
Reply to yadge
Posting while working, well, sometimes things like this get out. I'm not perfect. The 9600/3850 are the choices.
Reply to radnor
^^^ :lol: :lol: :lol: (@yadge's post...)
mowogo1820 wrote :
My monitor seems to have problems with VGA to DVI Adapters. I've tried and get no picture. I've tried b
mayb that adapter was faulty....did u try a diffrent adapter or did u try testing ur adapter with a difrent PC....i say u check and be 100% sure u cant use DVI.....u wont get many good cards with vga dese days.
i think 3850 has one
http://www.newegg.com/Product/Prod [...] 6814261019
Message edited by sarwar_r87 on 08-14-2008 at 01:03:48 PM
------------------------------ x2 5600+@2.8; 2GB RAM 800Mhz; xfx 9600GT xt; 320GB HDD; 420W thermaltake PSU
Reply to sarwar_r87
Sorry, didn't mean to be offensive. Just teasing. It happens to everyone.
Reply to yadge
And you did well. When one loses the ability of laughing at himself, there isn't much left to loose. So, it was kinda funny actually. No offense taken mate :)
Message edited by radnor on 08-14-2008 at 01:09:31 PM
Reply to radnor
I've Tried using other adapters. My current graphics card has both a VGA and DVI. It came with an adapter and I've used the same adapter on other systems and it works fine. It just doesn't work with my Monitor.
Thank you all for the rest of the comments/ recommendations you've provided me with.
Reply to mowogo1820
There are 545 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
