os instalation problem
my sata hard disk is not detect in instalation of win xp sp2 how can I solved this problem?
1 answer Last reply
More about instalation problem
  1. Turn off your computer then check that the power and sata cable connecting this hard disk to your computer is plug in securely. Power up then go to the BIOS and check that the hard disk is detected, once detected you will be able to install windows XP.
Configuration SATA Hard Drives Windows XP
