Tom's Hardware > Forum > Overclocking > CPUs > [Solved] Will better cooling allow more GHZ??
Forum Overclocking : CPUs - [Solved] Will better cooling allow more GHZ??
Best answer from Helloworld_98.
Hi guys,
im running a AMD 5200+ dual core (2.7GHZ stock)
with the auto over clock profile at highest (%7) sets cpu to 2.89 GHZ
when i put on manual overclock, any more than 216 MHZ (2.94GHZ)on cpu frequency
makes my computer shut down, after "save and restart" from bios,
im guessing its because its too much ? or too hot?
anyway at 216 MHZ (2.94GHZ) it doesnt shutdown, and runs games fine etc (stable?)
so will running an aftermarket cooling sink allow me to push my cpu more?
thanks
it won't get much further, athlon's don't OC very well.
Sponsored Links
Best answer
Message edited by Helloworld_98 on 08-25-2009 at 12:27:32 PM
Reply to Helloworld_98
Maybe. But like helloworld said, athlon's do not OC very well.
Reply to jsc
90nm, not likely, 65nm maybe, i got my x2 4400+ brisby from 2.3 to 3.0, try decreasing ht multiplier
------------------------------ "Envy is ignorance" - Henry Thoreau : Best quote ever.
http://www.pingtest.net/result/3022953.png
Reply to xaira
sweet, il try that, im guessing its somewhere in the bios?,
many thnx
Reply to rodney007
There are 1183 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
